Xantis - Interchangeability of streening pinion valves
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
Does anyone know what are the differences between the following steering pinion valves
4048F9
4048P1
Are they interchangeable ?
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
(Donor 2022)
x 8
Re: Xantis - Interchangeability of streening pinion valves
Any one knows if they are interchangeable ? ?
aerodynamica
x 215
Unread post by aerodynamica »
Can't someone with access to the Service site punch in the part numbers?
Graeme M
x 1994
Unread post by Stickyfinger »
lancia58
(Donor 2022)
x 8
So can the 4048F9 be used instead of the 4048P1 ?
x 1994
Not a clue.....I cannot think many people would of tried as not many are in your (geographical) situation with limited spares/2nd hand units available.
x 1463
Unread post by xantia_v6 »
I would say that the information suggests that they are not interchangeable, one is for cars with sinking suspension and FDV, and the other is for later cars with more conventional steering hydraulics.
lancia58
(Donor 2022)
x 8
What is FDV ?
x 1994
Flow Divider Valve
x 1463
lancia58 wrote: 12 Aug 2017, 11:20 What is FDV ?
See page 38 of this (very helpful) guide. http://citroenkerho.fi/xantia/pdf/tekni ... kaopas.pdf
lancia58
(Donor 2022)
x 8
Very helpful indeed
Peter Duncan
Unread post by Peter Duncan »
"Are they interchangeable ? "
These ones are usually identical except for the high pressure input side. Some require a seal, some are metal on metal like on pump side also. If you transfer your old input socket to the new one it should work anyway. Same for the return side but imho those are similar (at least the ones I've seen).
