Whats this pipe?
elma
x 284
Whats this pipe?
Unread post by elma »
Can anyone id this hose please?
Its dripping what seems to be fresh water rather than coolant.
I cant see anywhere it should be attached to.
Its on my xantia (v6). It goes into the bulkhead jyst above the plastic bag steering rack gaitor.
Own work
Own work
Own work
Own work
Own work
Own work
x 1493
Re: Whats this pipe?
It's the drain from the AC, totally normal to be dripping clean water
elma
x 284
Brilliant, that'll be because it was regassed this morning.
Thank you Richard.
x 8418
I've once seen a case of where that was broken - you have to be cautious with it if you ever have reason to remove the heater box complete - and the effect was a persistent leak of water into the passenger compartment ending up under the passenger footwell carpet...
Same symptom as a failed scuttle seal...
I fixed it by sleeving it with a tight-fitting length of plastic pipe covered in silicone RTV sealant...
elma
x 284
Exactly how I fixed the rocker cover oil hose that snapped in half when I touched it. I used the loctite from the sump repair though as i know its oil proof.
x 8418
I've fixed hydraulic pipes in a similar way except the 'adhesive' has been braze in those cases ;)
x 1940
No need for the quotes around adhesive Jim. Brazing is a gluing process similar in action to the hot melt glue gun or solder.
Now bronze-welding (what people frequently misidentify as brazing) is different as it penetrates the surface of the metal and mixes up the molecular structure a bit.
elma
x 284
Ooh bronze welding, thats new on me. Off for a bit of a read up, sounds exciting.
