Can anyone id this hose please?
Its dripping what seems to be fresh water rather than coolant.
I cant see anywhere it should be attached to.
Its on my xantia (v6). It goes into the bulkhead jyst above the plastic bag steering rack gaitor.
Whats this pipe?
- x 1492
Re: Whats this pipe?
It's the drain from the AC, totally normal to be dripping clean water
elma
- x 284
Brilliant, that'll be because it was regassed this morning.
Thank you Richard.
Thank you Richard.
- x 8417
I've once seen a case of where that was broken - you have to be cautious with it if you ever have reason to remove the heater box complete - and the effect was a persistent leak of water into the passenger compartment ending up under the passenger footwell carpet...
Same symptom as a failed scuttle seal...
I fixed it by sleeving it with a tight-fitting length of plastic pipe covered in silicone RTV sealant...
elma
- x 284
Exactly how I fixed the rocker cover oil hose that snapped in half when I touched it. I used the loctite from the sump repair though as i know its oil proof.
- x 8417
I've fixed hydraulic pipes in a similar way except the 'adhesive' has been braze in those cases
- x 1940
No need for the quotes around adhesive Jim. Brazing is a gluing process similar in action to the hot melt glue gun or solder.
Now bronze-welding (what people frequently misidentify as brazing) is different as it penetrates the surface of the metal and mixes up the molecular structure a bit.
elma
- x 284
Ooh bronze welding, thats new on me. Off for a bit of a read up, sounds exciting.
