Elmas Xantia V6 and Musical Stuff
DHallworth
x 159
Re: Elmas Xantia V6 and the joys of the countryside
Unread post by DHallworth »
It's not 2,3,4, and 5 I meant when we spoke Alisdair :)
It looks to me like it's the 90 degree bend on yours that's leaking where the 2 plastic collars hold the pipe to the elbow that goes into the bulkhead. If you remove that and then gently use a hacksaw to cut the collars off, you can use any Xantia elbow on the V6 pipes.
The elbow on my V6 breaker split when I removed it so Robert cut the collars off, used the original TCT elbow and jubilee clipped the V6 pipes onto it :) That pipe was NFP in 2014 so this was the only thing we could do.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
x 1777
Unread post by Stickyfinger »
Thanks for clearing that up David......
elma
x 287
Unread post by elma »
That's not making sense right now but I've just got back from London having left at 5 something this morning. I'll reread it in an hour and I'm sure I'll understand.
Doesn't sound like a terribly hard fix.
By any Xantia elbow do you mean a part Citroen still sells!?
elma
x 287
Stickyfinger wrote:I have a set of Front (Brembo) and rear disks surplus to my needs, we can work out a better price than that.
I only just noticed your post, getting up 2.5 hours earlier than I'm used to has really impacted me today.
Sounds like a great idea to me :wink: , name your price. If I'm saving money I'm happy.
x 7400
I've used a 'foreign' elbow in the past on a V6 and used Jubilee Clips and joiners to link up with the original pipes...
Worked a treat...
Be aware the Berlingo uses the same sort of elbow and could be a source of spares...
elma
x 287
Sounds like the beginnings of a plan. So it's basically hacksaw off the bit of pipe at the level the rubber hose attaches and fabricate a new elbow joint? I have a trusted plumber here Thursday and Friday, I will see if he has any good bits in his van that can be repurposed.
x 7400
When I say a 'foreign' elbow James, I mean one off a different model of Xantia. Not something Mr. Koslowski the Polish Plumber might have in his box of of miscellaneous fittings ;)
Joiners need to be 19mm in diameter... 22mm copper water pipe is a tad too big in my experience...
elma
x 287
Shame, I thought I'd fix it without leaving home.
Is this a part I can order new from Citroen or do I need to look for a decent used part?
I'll still interrogate the plumber, he may well have some good advice and possibly a useable pair of 19mm elbows that I could pinch.
I have appropriate clips the correct size from the LHM pump pipe, I ordered 10 or something as I thought they'd come in handy.
I didn't get around to the pipe or seats today, ended up doing 12 hrs work so although there was time and daylight I was too fatigued.
Davids post makes perfect sense now I'm fed and back with it. Chop off the collars and replumb with a new elbow. How is the actual elbow removed? David I've pm'd you my email address as I cannot see your picture and I'm sure it would explain a lot. If you can email me a copy of the picture I'd be most grateful.
x 1777
In my car and the pipes removed from the scrapped V6
x 1777
interesting that David's fixings differ to mine....or are these the converted type ?
elma
x 287
Mines exactly the same as Davids but still has the collar attached.
I was actually quite baffled looking at yours which seem to resemble the service citroen diagram more closely.
I've got my head round it now.
I'll see if I can obtain a spare elbow before I start plus 2 o rings.
If not I just have to have a go before I leave for Wales.
Worst case is I fail and bypass as you suggested, can't be running out of coolant midway.
x 1777
Yep, my matrix was replaced a few years ago according to the French invoices I have.....
elma
x 287
Right I'm ready to tackle this now, Davids given me some really good advice via email so I'm fully briefed.
I'll order a pair of o rings for reassembly and get cracking, ooh poor choice of words no cracking please.
I think I'll wait for the last minute with this job and see if I can obtain a spare elbow first.
I'll scour service Citroen tomorrow to see if they still exist for any model and place a wanted advert as well.
For me this is probably the scariest job I've undertaken on a Xantia. I mostly drive at night and the thought of having to blank off the heaters if I fail is totally unbearable.
x 1777
I will look at the ones on the breaker, you never know but everything else is good....just in case, but new would be better.
elma
x 287
Appreciated, you're being a massive help getting this car sorted and I'm totally indebted to you.
