I'd leave it alone, they're a devil of a job to get right and pretty delicate, you could finish up in worse bother.Trainman wrote:following on from Gibbo's point yesterday, the pointer is here:
which does lead me to believe the pointer is out, now for the strip down..............
It's been a while (C5 Adventure)
- x 2943
Re: It's been a while (C5 Adventure)
Trainman
- (Donor 2018)
- x 43
done, but how right it is, only a road test will tell.......... on a side note, I thought I had a couple of bulbs out in the dash, turns out they're LED's
Just taken it for a run, at 60mph on the speedo, the app show 58mph so I'll leave it at that.
Steve
http://c6owners.org/index.php
- x 2943
Nice work, as I said they can be tricky to get right, shame about the leds but I'm sure you could pop them out and solder in some replacements.
Trainman
- (Donor 2018)
- x 43
I did think about changing the LED's but then again, I'm not sure they're not working, I expected more lights on the dash, like the C6 and they just aren't there.
Plus I'm only planning on keeping this for 12 months.......
Steve
- x 5612
Can you compare with your dad's C5 Steve? Should be the same.
Trainman
- (Donor 2018)
- x 43
Just done that Steve, it's about the same, so I'm leaving it alone now.
Steve
- x 8172
Good work Steve
Fingers crossed all will now be perfect...
Trainman
- (Donor 2018)
- x 43
Next few jobs require a trip to ebay for bits but that can wait until later........
Steve
- x 694
The unanswered question of course, is how did the needle end up so far out of position ?
- x 8172
Knowing how the needle is keyed onto the stepper motor shaft may offer a clue...Mandrake wrote:The unanswered question of course, is how did the needle end up so far out of position ?
My money is on the stepper motor having been changed at some point in the past and no care was taken to ensure the needle was correctly placed...
Trainman
- (Donor 2018)
- x 43
I did contemplate swapping the stepper motors over, but decided against it. I did wonder if they had been swapped over before.......
Steve
- x 2943
IIRc it's just pushed on to a taper so no key.CitroJim wrote:Knowing how the needle is keyed onto the stepper motor shaft may offer a clue...Mandrake wrote:The unanswered question of course, is how did the needle end up so far out of position ?
elma
- x 287
That would make sense as it would park without obscuring the lcd display.
Trainman
- (Donor 2018)
- x 43
Managed to get Lexia on the car today, (Dozy hole, here forgot I'd installed version 5.02 to an old XP laptop I had in the loft)
I've got 3 faults, so I'll have a look at these over the next couple of days:
For a 15 year old car, I'll settle for these.........
Steve
- x 3281
Steve, I believe that those may be 'phantom' faults. I wish I could remember who (on this forum) mentioned them, but I did, quite some time back, find I had those same three faults on my C5, and the codes matched the Citroen C5 phantom faults.
