Lidl and Aldi Car accessories
- x 3306
Re: Lidl and Aldi Car accessories
On Sunday (26/03) Lidl are doing some more cycle items;
https://www.lidl.co.uk/en/Non-Food-Offers.htm?id=145
- x 8368
Thanks James
That bike stand has got to be worth a go, been meaning to get one for years... The cyclists equivalent to a set of ramps...
demag
- x 102
Alasdair you want Zebra Stove Black.
Dave
- x 2000
The stove is in the workshop, I used 20/50 oil in the end then cooked it hot with the workshop door opened , its black now !
demag
- x 102
Lidl's finest.
Dave
- x 8368
They look OK Dave...
Not bad at all
Not bad at all
elma
- x 287
Don't buy that repair stand Jim, I had a look and it's not great. You can have my park one in return for all the help you've given me and the ongoing support with my Xantia
- x 8368
That's a deal Jameselma wrote:Don't buy that repair stand Jim, I had a look and it's not great. You can have my park one in return for all the help you've given me and the ongoing support with my Xantia
Likewise, anyone is advised to avoid the Lidl Dansette-style retro record player they have at the moment...
Not good at all...
elma
- x 287
I shall drop it to you along with Gabriels clutch cable on my return drive as planned already Jim.
In fact I've got a good collection of prity top end cycling tools including headset remover + installation tools, star nut setter, specialist spanners, Bottom bracket tools etc. It took a lifetime to collect so you can't have them but if you'd like to be there custodian until I cycle again you are welcome to have a long term loan.
I have to clear my container out in N Wales so you'd actually be doing me a favour.
demag
- x 102
I bought some pc speakers from Lidls once. They were not good, very tinny and no midrange or base. Admittedly they were cheap so I took them to work and one of the lads put them on his works PC.
Dave
- x 8368
James, that'll be really lovely and very, very much appreciatedelma wrote:I shall drop it to you along with Gabriels clutch cable on my return drive as planned already Jim.
A lot of their cheap electronics is just re-badged mediocre Chinese stuff sadly which is a shame as so much of their other stuff is, for the price, pretty well excellent...demag wrote:I bought some pc speakers from Lidls once. They were not good, very tinny and no midrange or base.
Their record player has class D audio amplifiers for heaven's sake. That's just a travesty when it come to reproducing vinyl
- x 3306
As there has been mention of motorcycles elsewhere on the forum I thought I would mention that next Thursday (30/03) Aldi have a few motorcycle bits;
https://www.aldi.co.uk/c/specialbuys/da ... ing&page=0
Zelandeth
- x 1593
Well I can state that their little 12V oil transfer pump does what it says on the tin. In one steering box oil top up it's already been worth its £12.99 pricetag!
It seems really to be aimed at pumping oil out of engines (though I've already got a vacuum based pump for that), but I reckon is much more useful for pumping oil IN to things.
States in the manual that it's not meant to be used for draining gearbox oils, not sure whether due to the viscosity or potential for metallic debris to damage the pump. It did just fine pumping a few hundred ml of EP90 into my steering box and back axle. Reckon the biggest challenge with the factory setup is that the pickup tube is quite narrow. Reckon it would cope just fine with a wider hose.
Was going to use it to check the gearbox oil as well - but couldn't get the level plug out...
That's my problem not the pump though! Definitely will be keeping that around, useful bit of kit.
Current fleet:
- x 3306
On the 11th May Lidl are doing some DIY stuff, including welding equipment;
https://www.lidl.co.uk/en/Non-Food-Offers.htm?id=191
and on the same date Aldi have a few bits and pieces, including a dash cam;
https://www.aldi.co.uk/c/specialbuys/da ... lar&page=0
demag
- x 102
I wouldn't bother with the baby welder but the inverter one will probably be ok. I might take a look at the dashcam as well.
Sent from my Nexus 7 using Tapatalk
Dave
