Hello again. Here's hoping for suggestions on how I might sort weird window behavior. After ignoring the front passenger window's refusal to work it has decided to spit the dummy and let itself down. It all started with a refusal to come fully down and stayed stuck....I checked all the connections and switch and when battery was reconnected the thing worked..sort of.
I left it up because it stopped working again...: that was six months ago. The cars been sitting for a while under a cover for a couple of weeks and when I took the cover off to give her a country romp found the window had let itself down!!! And there it is. Down. Wont go up and wont go down. All other windows work fine.
XANTIA V6 MK2 WINDOW ISSUE
hattershaun
- x 4
Re: XANTIA V6 MK2 WINDOW ISSUE
Your window regulator may need replacing, either the cable has snapped, come off the guide rollers or the rollers have disintegrated.
I had this on my Xantia and it's a common happening on XM.
A chap in the UK used to sell replacement cables repair kits on eBay.
Shaun
C6 3.0 HDi Exclusive - 2010
SM 3.0 - 1972
DS 23 Pallas - 1975
GSA Pallas C-Matic - 1982
SM 3.0 - 1972
DS 23 Pallas - 1975
- x 8466
If the car has been standing for a while it's worth checking too the window guides are not very stick and gummy. This can cause the anti-pinch system to come into operation at the wrong time in the belief that an object is preventing full closure of the window.
As Shaun says, there is a very common problem with the S2 Xantia cables and this is normally the result of the plastic clip between the cable and the window glass breaking... Always a good idea to have a few spares on hand...
The cables can get very tangled but a bit of care will enable then to be untangled and re-strung.
The clips are still very much available on eBay here, for example
- x 3298
I would suggest (once you have got the window working again) you spray some silicone lubricant along the guides. The driver window of my C5 was getting awkward, and I read somewhere on this forum (with a video link) that silicone lubricant (which is water repellent) helps sort this out. Yes, it does. I will need to apply it again (it lasts about a year or so), but the window was far more reliable.
- x 2008
The same stuff works on your slow to return seatbelt FYIHell Razor5543 wrote:I would suggest (once you have got the window working again) you spray some silicone lubricant along the guides. The driver window of my C5 was getting awkward, and I read somewhere on this forum (with a video link) that silicone lubricant (which is water repellent) helps sort this out. Yes, it does. I will need to apply it again (it lasts about a year or so), but the window was far more reliable.
Moss
Thanks for your suggestions fellas. I managed to get the regulator assembly out though wondered about the mental state of the "designer" of the block clip setup". Mungrel. There is no visible issue with any part - plastic, wire or carrier. Not sure now how to test the black box/motor. Any suggestions on how to go about testing?.
- x 8466
I would firstly clean the window guide rails very carefully and check, with the regulator assembly out, that the glass slides very freely up and down...
The regulator mechanism can be tested without being 'connected' to the window glass, just be careful not to over-run it at the extreme ends of travel.
I can supply a wiring diagram if that would help?
- x 6950
Does rhe motor make any noise when operating the switch? If not, then I would check the wiring loom on both Driver and passenger sides at the door hinge areas. They may be contained within a protective sleeving that you can undo. It's not uncommon for a break to occur in this area over time.
Moss
Thanks for the offer of a wiring diagram Jim....think I'm going to need it....just can't figure how the window got lowered ... don't think a wire short at the door exit could send the thing into down mode given it was just sitting around.
- x 8466
Here you go sirMoss wrote:Thanks for the offer of a wiring diagram Jim....think I'm going to need it....
Front Electric Windows Circuit
Front Electric Windows Harnesses
Front Electric Windows Locations
Hope they help solve the issue
Moss
Well finally got time to look at the wiring, had been thinking switch was dodgy because the window let itself down. Pulled the switch out and HO! three wires had popped. Put them back by looking at length and probable spot method (otherwise known as R.S.B.) and plugged the power assembly in then flicked the switch. Cooked a wire...melted the insulation in a flash so now know there's juice coming to the switch. Now don't know weather the motor is the problem or the switch so plan on getting the motor checked.
