Urgent C5 radiator fan help needed
x 1746
Re: Urgent C5 radiator fan help needed
Yes, sorry - single fan on yours.
There is also a controlling relay attached.
Check out both fan and relay independently, and the supply to them.
You can substitute the fan with a high wattage lamp (eg 12v 100W, or 55W) for testing purposes.
boristhespie
x 4
Unread post by boristhespie »
Was a melted connector.
C'est pas possible!
x 5688
Stickyfinger wrote:Single fan, single relay on mine.
Same here and I could be in trouble - had the bumper off to replace a blown bulb and the fan is sticking.
Should be OK until next April though, temperature never varies :)
x 2008
Unread post by Stickyfinger »
I tried but could not gain access into the motor, I expect it is brushes causing the problems.
x 5688
It just seems to be "tight" at one point in it's rotation. Very tight, wouldn't budge at first.
x 1955
I would try some oil on the shaft to see if it can seep in and loosen it off. It will probably be best to take it out of the car first so that you can place it face down so that the oil can follow gravity.
Having said that, it'll probably not fix it. I never had any success with the fan out of either the C5 or the Xsara!
boristhespie
x 4
Saved a bunch on the fan ordering from that link. 500 vs 230.
Now got fault codes which are troubling from what I have read from searching this place.
C'est pas possible!
boristhespie
x 4
800 smarkeroonies all in. Feeling sick.
C'est pas possible!
x 1955
Has that solved all your current problem(s) though?
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
ouch!
x 2008
WHY ?
30mins bumper off, 30 mins to change the fan, 30 mins bumper back on + £230 for the fan unit.
boristhespie
x 4
Time taken looking for electrical fault. Then the Eolys was topped up and that stuff cost a load. £550 garage add the fan 250 (including postage) 800.
C'est pas possible!
x 2008
fair play, other stuff as well.
x 1955
Boris
Paul-R wrote:Has that solved all your current problem(s) though?
