Sphere tester
kiwifrog
Sphere tester
Has anyone made there own sphere testing rig ? Im keen to make one , Im an engineer and have high pressure gauges and fittings etc.
- x 5677
Re: Sphere tester
Indeed you can, Jim made his own. See here.
- x 1746
Re: Sphere tester
If you are intending the regas your own spheres, the Tecnosir C720 regassing tool is also capable of checking a sphere's pressure, once the regas valve has been fitted to the sphere. This can also be done on the car, if the system pressure is relaxed.
xantos
- x 10
Re: Sphere tester
And here is mine made from hydraulic jack and rear Xantia cylinder... Works great and simple to use and manufacture...
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet
C4 Exclusive 2.0 HDi (gear shifting b****!)
- x 1746
Re: Sphere tester
That's extremely neat and simple, Xantos.
The view from the workbench is also rather splendid!
- x 695
Re: Sphere tester
Also check out David's sphere tester:
http://www.frenchcarforum.co.uk/forum/v ... start=1440
It's a commercially made one but is very simple and shows exactly what is needed.
