Help - please - I have my C8 that was running absolutely fine and now will not start - the engine turns over but does not fire. I have had it transported to my local (trusted) garage and they cannot get their Snap-on computer to talk to the engine ECU - it will talk to all the other ECU's e.g. airbag etc. - it has been suggested by another garage that the 'Protection Relay' may be faulty but where is the protection relay located ? is this the Brown double size relay referred to in other (non C8) posts.
The other symptoms are - no fuel pump operation, no window operation
Any help would be appreciated.
C8 Engine turns but will not start
- x 1955
Re: C8 Engine turns but will not start
I can't help but it may help if you can add some details such as what year, which engine and, possibly important, how many miles.
- x 1061
C8's don't have double relays as such, the injection/fuel pump relay is an integral part of the under bonnet fusebox. You need to confirm if the ECU has all its power supplies & earths.
geoffarm
Hi - sorry I should have provided the car details
2006 C8 Exclusive HDI 16v Automatic Diesel
113,564 miles
The relay I am trying to replace (once I have found it) is a 1920 7L - brown double relay - sold to me by my local Citroen dealer - it is listed on the Citroen Service website under Engine --> Air and Fuel Supply --> INJ CALCULATOR SENSOR --> item no 2
This is the relay
I am lead to believe that this is the Fuel Pump and ECU relay.
Thanks for any help you can give
113,564 miles
This is the relay
- x 6950
Can you PM your VIN and I'll have a look to see if I can find any documentation for you
geoffarm
Is the relay I have shown not the correct one - it is listed on the Citroen parts list for the car VINwheeler wrote:C8's don't have double relays as such, the injection/fuel pump relay is an integral part of the under bonnet fusebox. You need to confirm if the ECU has all its power supplies & earths.
- x 2008
GiveMeABreak wrote:Can you PM your VIN and I'll have a look to see if I can find any documentation for you
- x 6950
At least give me a clue Alasdair, crystal ball is spent on other posts this week!Stickyfinger wrote:GiveMeABreak wrote:Can you PM your VIN and I'll have a look to see if I can find any documentation for you
- x 6950
I've got your PM - you didn't include an email address though. I have some documentation, but I can't send it on without an email (don't post your email here)geoffarm wrote:Is the relay I have shown not the correct one - it is listed on the Citroen parts list for the car VINwheeler wrote:C8's don't have double relays as such, the injection/fuel pump relay is an integral part of the under bonnet fusebox. You need to confirm if the ECU has all its power supplies & earths.
- x 2008
- x 1061
As i said in an earlier post the injection/fuel pump relay is an integral part of the under bonnet fusebox thats probably why you cant find it. Did the parts department search for this part from your VIN??geoffarm wrote:
- x 5688
Stickyfinger wrote:sorry.....miss post.....
- x 2008
