C5 in for MOT tomorrow
- x 1987
Re: C5 in for MOT tomorrow
Well I just crawled under (car on drive up ramps) and sure as rain the plastic was all flake. All wire brushed off, rust converter and painted. My bushes seem to be OK but I think I have just caught it in time.
Dogbone finally changed to the new one I have had for six months.
Main sphere block is getting attacked big time....again wired brushed, converter and paint, will "waxoil" it when the paint is dry.
There are two HP lines whose crimped collars are also corroding badly, I urge you, if you have a C5x7 to GET UNDER the car and protect these as a matter of urgency.
jgra1
- (Donor 2021)
- x 36
Ahh .. if I have a bit of luck I will be doing exactly the same on sat/sun sf.. new dog arrived a few days ago..may paint it ! Will brush the arb and paint ..
Just the small matter of the mot .. first
- x 1987
There is a short rubber HP hose forward of the central sphere block....crimped fitting at each end.....CHECK it.....mine were all flaky with rust on both ends and maybe will not hold much longer.
Love the small welded (to the floor) studs for the rear exhaust box heat shield.....2x rusted off and 2x washers/nuts missing having not been replaced at some time.....wondered what the rattle was so I have stuck the bugger up with black windscreen adhesive as a temporary measure:)
All cleaned, treated, painted and a liberal coat of waxoil .....all else seems dry so fingers crossed
Sloppysod
- x 386
almost fell of the chair laughingjgra1 wrote:....new dog arrived a few days ago..may paint it !
Stu
jgra1
- (Donor 2021)
- x 36
although, going off subject slightly.. I was fortunate to meet some wild 'painted dogs' last November!
- x 6955
Thanks for the warning - time to get a pair of axle stands me thinks!Stickyfinger wrote:Well I just crawled under (car on drive up ramps) and sure as rain the plastic was all flake. All wire brushed off, rust converter and painted. My bushes seem to be OK but I think I have just caught it in time.
BenC5HDi
- Not Mike
- x 45
Owning a C5 X7 seems like a hell of a hassle! I was under the C1 today, 06 plate.. no rust at all apart from surface rust on the exhaust. You can even tell it's red underneath. All this waxoyling and wire brushing? Not for me thanks!
- x 1987
To be honest....I should of done this a long time ago.....some old French thing took my time up
It is not a lot however, easy access and a simple job. It is also exactly the same as any car these days, powder coating is a standard practice (even if sh1t) as it is the cheap way....Do NOT ever look under a 8 year old BMW or Ford.
You cannot blame the C5x7 or Citroen as it is hardly unique in having a few "areas" that need treatment after 100K miles and 8-9 years on roads in the UK winters.
daviemck2006
- x 496
Re: RE: Re: C5 in for MOT tomorrow
C1, 107 and Aygo do not rust. If you see a rusty one it has been damaged and poorly repaired. If you want a small car to simply drive and simple to service they are the car to get. No question in my eyes. Even if they need a clutch, £75 and two hours book time to change it. Bet Jim is wishing an activa was so easy [emoji13] [emoji12] [emoji23]BenC5HDi wrote:Owning a C5 X7 seems like a hell of a hassle! I was under the C1 today, 06 plate.. no rust at all apart from surface rust on the exhaust. You can even tell it's red underneath. All this waxoyling and wire brushing? Not for me thanks!
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 1987
Yeh but do not loose the box it came in, it badly effects the resale value at the toy fair
There is no rust on the car......just some bits attached to it
(the normal Citroen bits that they spent 60+ years developing to a state of the art system that still corrodes
- x 1987
Well don't I feel like a BIG Pri3k !
Miss read the date.....28th June !.FECK !
anyway, my phone broke this morning so God knew about it anyway
elma
- x 287
Brilliant!! Did you drop the car at ythe garage before you realised?
- x 6955
I'd loved to of been a fly on the wall when you realised!
- x 1987
Really....I am such a pratt
.....I drove in directly onto the ramps, he checked the Vin, signed on to MOT systems and then I popped his head out the door and called me over whilst laughing his head off.
Lucky for me my local "small garage" is most friendly.....however the whole workshop had a giggle
(but no charge)
(but no charge)
- x 6955
I doubt even you would manage to get 2 months added on to the MOT!Stickyfinger wrote:Really....I am such a pratt.....I drove in directly onto the ramps, he checked the Vin, signed on to MOT systems and then I popped his head out the door and called me over whilst laughing his head off.
Lucky for me my local "small garage" is most friendly.....however the whole workshop had a giggle![]()
(but no charge)
