C5 in for MOT tomorrow
- x 1996
jgra1
- (Donor 2021)
- x 36
Re: C5 in for MOT tomorrow
Good.luck for it
OnlineHell Razor5543
- x 3296
It will pass, if you have looked after it the way you are working on that V6 Activa.
- x 1996
I have concerns about the rear Anti Roll bar bushes (you cannot get a bush just the whole bar @ £BIG ) and as always, everything else on a big Citroen
JohnD
- x 72
March & April is always a worryingly busy time for me. I have three family vehicles all due for a test within a few weeks of each other. Happily, they've all recently got new certificates.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
- x 1996
superloopy
- x 19
I'm pulling a couple of mine and sorn'ing until the weather improves. Much better to have an mot due in the summer than at this time of year. Gives you a fighting chance of prepping in a tad of warm weather!
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
jgra1
- (Donor 2021)
- x 36
Agree with weather ! I am 6 mots in since November. And the luck ran out with the x7 ..the newest vehicle by far of all of them ! Other 5 fine thank goodness
- x 1940
How old is the X7? And how many miles has it done? Must confess a selfish motive in asking as I'm concerned over the (hopefully long term) future of my X7's rear A/R bushes also.
Oh - and good luck!
Oh - and good luck!
Sloppysod
- x 396
I must be lucky as I have the wifes in September and my X7 in April.
Sent from my GT-I9195 using Tapatalk
Stu
jgra1
- (Donor 2021)
- x 36
Hi.paul.. mine is 120k . and 6.. sf's is a couple.of years older but can't remember the mileage..I will grab a pic of the arb later on.. it does look like an issue waiting to happen
- x 1940
Yes, I agree.
I've seen mention of getting urethane bushes made. They'd probably have to be split to replace the old rubber ones I guess.
Going back a few decades I did have a contact for urethane bushes for MGBs and Sprite/Midgets. ISTR that they were moulded and came from Australia. Unless we could get a decent order together I think we'd have to get ours machined from blanks.
- x 1996
102k, 2009 estate car.
The "problem" is that the bush is bonded and the bar is powder-coated , so a hard plastic on a flexible bar with a bush bonded to the plastic coating.
When the plastic gives up the bits eat the bush and you have to purchase a new bar as a complete unit.
- x 1940
Yes, I've seen that reported.
I'm thinking of something along the lines of removing the remnants of the plastic coating and running a split urethane bush directly on the steel surface. It wouldn't be bonded but the bar would rotate inside the urethane bush - as it should do for the rubber bush really. Maybe a touch of grease to slow down any rust on the steel of the A/R bar.
- x 1746
PU bushes run and wear superbly, and far outlive many OE 'rubber' ones.
This company stock a massive range of PU items:
www.priracing.com
(in Cheadle, Cheshire)
Bushes manufactured by www.superpro.com - see their site for the full range.
PU bushes best lubricated with silicone grease (available from PRI too).
www.priracing.com
