Lexia woes
BenC5HDi
Not Mike
x 45
Re: Lexia woes
Unread post by BenC5HDi »
I have run the checker on my Lexia and the results are below.
If it's one I can flash, please can you direct me to the files please Marc. I've emailed you..
Sent from my SM-N9005 using Tapatalk
x 6957
Re: Lexia woes
Replying now Ben - give a few secs to upload the links....
Edit: Done
BenC5HDi
Not Mike
x 45
Re: Lexia woes
Great, thanks a lot Marc. I've flashed it, as per your suggestion of one step at a time up to v4.33
I'll now reinstall DB7.02 and upgrade it to 7.15 and seen if it works this time.
BenC5HDi
Not Mike
x 45
Re: Lexia woes
Well, despite Marc's great help - Diagbox 7.15 now installed and activated, Lexia interface updated to 4.33, I still can't get any dialogue with any ECU - every single one comes up with NO. I suspect the cable between the Lexia and the socket is duff, as I get exactly the same result when I simply leave it unplugged.
I checked fuse F6 - the diagnostic socket fuse, it's ok but I replaced it anyway.
So, looks like my hardware is duff :( I'm even more inclined to think this as Hell Razor James Lexia worked fine on this vehicle a couple of weeks ago.
Damnit.
KP
x 27
Re: Lexia woes
Unread post by KP »
If you suspect the cable then there is somewhere in the UK that makes ones hat work perfectly fine. Mine was like this with some ECU using the older 30pin breakout cable but once i spent the £25 on a replacement it's worked faultlessly :)
x 3306
Re: Lexia woes
Well, Ben's cables work on my system, but when I try using his Lexia I cannot 'talk' to the ECUs. However, the firmware checker works. I know that my Lexia, the short USB cable and the interface cable work.
x 1939
Re: Lexia woes
Two questions.
Have you tried your Lexia on another car?
Has your car been read by another Lexia? Failing that a generic reader? (You may have said so already, if so I apologise).
x 1939
Re: Lexia woes
Cross posted with Hell Razor which partially answers my questions.
john
Re: Lexia woes
Unread post by john »
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
x 6957
Re: Lexia woes
John - You have the revision B hardware - so are limited to the earlier versions of Diagbox 7. I don't have anything earlier than this now.
I've sent you a PM regarding the above.
x 1454
Re: Lexia woes
Unread post by xantia_v6 »
I am trying to check the version and diagbox compatibility of my old Lexia interface.
When I run the PSA Interface Checker.exe file, I get as far as the language selection screen, and then the installer crashes.
I have an old copy of Lexia software (still working) installed on the same (XP) machine.
x 6957
Re: Lexia woes
Once you've selected the language, there's nothing to say that it has installed (!) odd, I know,, but you should have 3 icons on your desktop - DRIVER, INTERFACE INSTALL and PSA INTERFACE CHECKER. It puts all these on the desktop.
Ignore the first 2, just connect up your interface and launch the PSA checker. If there aren't any icons on the desktop, the executable file is here:
C:\APPLIC\LEXIA\MajAppCom\MajAppCom.exe
if this file is here, you can just create your own shortcut to it or launch directly. :wink:
If it isn't there, then try installing the programme as administrator (even if you are an admin).
x 6957
Re: Lexia woes
john wrote:Image
As there was no question in the post John, I'll just jump in and confirm you have the older blocked revision 'B' interface. You should be fine with Diagbox versions prior to V7 - or and a big or - you may get away with an early V7 - but it is hit and miss. If you don't need to upgrade your Actia, leave it as is. (I can't tell what car you have as you don't have it on your Avatar / profile :)
x 1454
Re: Lexia woes
GiveMeABreak wrote:Once you've selected the language, there's nothing to say that it has installed (!) odd, I know,, but you should have 3 icons on your desktop - DRIVER, INTERFACE INSTALL and PSA INTERFACE CHECKER. It puts all these on the desktop.
That information was useful!
My interface is as old as I thought... I don't suppose that there is much chance of it working with a Peugeot 308?
x 6957
Re: Lexia woes
What year is the 308? Here's the thing - depending on the year, some of the ECU software may of been written after the older PP2000 software was written, so some ECUs may not be readable; so now in addition, we have the added problem that Revision 'B' clone interfaces were 'blocked' by PSA. The revision 'C' clones are ok and should work fine with the all the current line up of cars, with the exception of a few commercial PSA vehicles. There are some guys who say they can reflash the Revision B interfaces to revision C for a small fee - before you can upgrade to the later versions of Diagbox - which in turn supports some of the newer cars.
Also, your firmware is currently 4.1.6 and Diagbox 7.01/02 needs 4.3.0 - but not much point if your interface may not work with V7. Appologies if this is all a bit confusing!
