Lidl and Aldi Car accessories
Re: Lidl and Aldi Car accessories
..not available at the minute but I bought one of these from Lidl for £2.99........absolutely spot on. Just did the oil filter on my Xsara Picasso 2.0HDi, quite awkward to get two hands round the filter, with all the various pipework in the way but the tool worked perfectly even in the confined space and plenty of leverage to remove stubborn filters even one-handed.
Picked it up from here, so thanks to James et al for the thread.
x 3296
Well, Lidl are doing a couple of car bits (and motorcycle bits) next Monday, 29/02. This includes an oil drainage pump;
http://www.lidl.co.uk/en/our-offers-249 ... d=777&ar=2
BenC5HDi
Not Mike
x 45
Unread post by BenC5HDi »
Why am I always working on these days when they have stuff I might want? !
x 3296
OK, what is it you are after THIS time?!?
x 2938
Just had a look at the oil sucker :) it says it takes 2 minutes to drain 0.2 litre of engine oil, runs off the car battery, I reckon my battery would be flat before my sump was empty. :shock:
x 8422
Decimal point in the wrong place?
x 3296
Doubt it, as it says 1.5l diesel per minute. I would guess that is an estimate, as we know that oil can have varying consistencies depending on viscosity, age and condition.
x 1997
Unread post by Stickyfinger »
I can RECOMMEND the wet/dry Vac guys
I use it for loads of stuff from draining water from radiators to cleaning the garage and wet floors/floods.
harryp
(Donor 2022)
x 73
Unread post by harryp »
I concur with wet vac use :) . Use a Hoover Aquamaster and have had 3, one new and a couple s/h for the motors :wink: Very powerful dry suck and superb on wet use. On Plumbers Forum one said he uses it when changing radiator valves by just putting the open hose under the valve and removing - no water on floor. I can believe it having cleared 4" U bends blocked with gravel. Small(ish), light and extremely portable.
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
x 1997
The primary reason I got mine was to drain down cast Iron rads....just shut off the valve and lock-shiled, crack the valve to rad joint and catch the flow
x 2938
I've got a Karcher Press and Ex 800 that must be 30 years old now and still working, although I did have to fit a new water pump to it at some time.
https://www.google.co.uk/search?q=karch ... U9TlRZM%3A
x 3296
Next Thursday Lidl are doing a load of tools, including combo ratchet spanners;
http://www.lidl.co.uk/en/our-offers-249 ... d=791&ar=2
x 2938
I bought one of the double ended grinders last time they were on, seems like a good tool for the money.
Not sure about the ratchet spanners they are too thick to get in many of the places you need to go.
x 3296
Well, for all the Cyclists amongst us (hello, CitroJim! :-D ), Lidl are doing a few bicycle things next Monday, 21/03;
http://www.lidl.co.uk/en/our-offers-249 ... d=795&ar=2
x 8422
Hell Razor5543 wrote:Well, for all the Cyclists amongst us (hello, CitroJim! :-D ), Lidl are doing a few bicycle things next Monday, 21/03;
Thanks James :D the work stand is definitely on my list. Want oner of those!
