C5 2.0 HDI intermittent non-start?
Post Reply
pabloalfa76
My Cars: Citroen C5 2.0 HDI Estate
Post by pabloalfa76 »
Hi All,
Citroen C5 2002 2.0 HDI.
My car will start and run perfectly, then every few days will crank but not fire up. It could take me 30-40 mins of on & off cranking until it starts.
When it does start, it does so effortlessly, with no smoke or coughing and spluttering.
This is as if the injectors are not switched on?
I've no lexia and so guessing at low fuel pressure.
I've done an injector leak off check and all levels are about the same amount. So assuming injectors are OK.
The in tank pump is working well.
The car drives very well with lots of power.
I have no warning lights on the dash, and it never goes into limp mode.
Has any one had a, Fuel Rail Pressure Switch causing problems?
jgra1
(Donor 2021)
My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong
x 39
Re: C5 2.0 HDI intermittent non-start?
Post by jgra1 »
hi Pablo, I had a similar issue with mine, for about 6 months I used easy start, once she was running it was fine! just starting.. I didn't know what else to do.. also she would cut out under heavy throttle!
I think I tried a handful of pressure regs.. this could certainly with the problem.. but once when I did a lexia diagnosis, I noticed one of the injectors correction was way different to the others.. I but the bullet and bought a second hand injector and fitted it easily.. the car still goes strong today, starts on the button.. and I cant tell you how nice it is now to sit in it on a winters morning and not have to feed explosives into the inlet pipe every day ;)
the moral is, get a diagnostic with a lexia and check some numbers..
John
bugger, just noticed you are in Forest Row.. I have lived there a few times and Sharpthorne..
only down the road now in Edenbridge..
pabloalfa76
Thanks, for the advice.
I guess I'm going to need to get it tested. I'm thinking of buying on off of ebay, so I can use it again in the future.
Is Lexia easy to use?
jgra1
(Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
x 39
Post by jgra1 »
I am happy to pop over to show you how it works Pablo, possibly for a pint in chequers ;)
I cant say I am that experienced with what to do with any information, but we can certainly get a diagnosis done and report back on here..
its no bother
I agree though that you should get one sometime
What happened with me, I had about 10 PSA cars and kept being told to buy a lexia, I got one and the result now is that I have to keep buying PSA vehicles!
pabloalfa76
Hi John,
Are you offering to use your Lexia, or Shall I pick one up and then make contact with you again?
Either way I'm happy to drive up to you if it helps.
Cheers, Paul.
jgra1
(Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
x 39
Post by jgra1 »
hi Paul, yes I can use mine on your car, no problems. drive this way via Hartfield or I can come over there. eves are fine weekends not so easy
pabloalfa76
Well it's starting to get me down, so lets do tomorrow evening.
Pm me your address and we'll work out a time, I'm probably about from 3pm. Hard to be exact as I'm out on the road all day.
Cheers,
citroenxm
My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising
x 71
Post by citroenxm »
Lexias are hard to use, but CAN be a real PITA to initially setup and get up and running!!!
They are worth gold once working!
A very sad...
1994 XM 2.1 d auto
pabloalfa76
Hi Again,
Ok, I met tonight with jgra1, who has kindly plugged Lexia into the C5.
I'll post up some screen shots for you to look at and hopefully someone with Lexia-HDI knowledge can offer some advice.
citroenxm
x 71
Post by citroenxm »
Dont take messages AS ACTUAL issues.. in other words the harness resistance could be an error caused by something else!
Firstly, does the car go into limp mode IE: Revs limited to 2.5 - 3k MAX ??
Those injector readings are all over the place!! Can you get your hands onto another set? Id say they were a bit all over the place and possibly causing your starting issue...
The Turbo pressure reading, reading high, that could be a faulty Wastegate control Electro Valve not shutting off and allowing over boost. Id try another electrovalve first. They are behind the passenger strut top, under the rear plastic cover.
A very sad...
1994 XM 2.1 d auto
jgra1
(Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
x 39
Post by jgra1 »
I agree Paul re injectors.. my c5 had one that was all over the place.. upon changing it the car never failed to start again and never cut out dangerously at speed under load! we noticed that Pauls 2 injectors (2 and 4) were way off the correction of the other 2 (1 and 3)
pabloalfa76
The car never goes into limp mode and has lots of smooth power through the rev range.
It does look like the injectors are a possible problem, do you think any of the injector readings are OK and can stay?
jgra1
(Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
x 39
Post by jgra1 »
http://www.frenchcarforum.co.uk/forum/v ... 00#p416200
Paul (Pablo).. - 19 pages - don't even go there..
but excessive leak off, caused by a dodgy injector, caused my bad starting (and my high speed cut outs)
pabloalfa76
Thanks, for the reply's, I'm off to bed now.
I'll get some new (used ) injectors in at the weekend and report back.
Cheers, Paul.
jgra1
(Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
x 39
Post by jgra1 »
I have just re read some of that hell, lol.. a new battery, a second hand injection pump, probably a load of fuel regulators, and finally an injector.. think I did some glow plugs too somewhere along the way
OMG ....
Post Reply
