2002 Citroen C5 3.0 V6 oil burning smoke smell...help
luqies
Re: 2002 Citroen C5 3.0 V6 oil burning smoke smell...help
Unread post by luqies »
Managed to find some time this afternoon. Opened the bolts. Could not open the last bolt as it was threaded. Can see last 1 still in.
Need a tip how to get a 8mm bolt out. The 8 socket is slipping and 7 too small. I'm a newbie with diy so any help appreciated. I'm lacking tools
Definitely oil leak. Also oil around spark plugs. I also see the burnt oil on the manifold.
x 1980
Unread post by Stickyfinger »
?? to clear
Does it just spin in the hole or is the head rounded off ?
luqies
8mm not enuf grip
7mm too small
x 3281
These are pretty good. I have (once) managed to remove a threaded rod that my brother had spent ages trying to shift. The downside is that (where the wrench gripped) the threads were knackered, but as it was somewhat rusty anyway he way going to replace it.
http://www.ukworkshop.co.uk/forums/supe ... 30793.html
x 1412
Unread post by xantia_v6 »
You could try a couple of imperial sockets if you have them, 5/16" and 9/32" are between 7 and 8 mm. For choice, use a 6 sided socket, not 12 sided.
With a flat punch and a heavy-ish hammer, give the bolt a good whack on the head, it will make it easier to undo.
x 1980
luqies wrote:8mm not enuf grip
7mm too small
So the head is rounded ....?
if so, a 5/16th socket should do.
luqies
I had an incomplete ratchet set. The extension was missing so when I get that piece I'll try again.
Anyway here is another pic
The hose was so brittle it just snapped off. Easiest cheapest way to fix?
Is insulation tape enough?
x 1412
That is just an oil breather hose, so can be replaced with anything the right diameter that will withstand engine heat and oil fumes. The hard part is joining it without breaking anything else.
I did fix one by finding a piece of copper tube (about 50 mm long) that fitted snugly inside, smeared the outside of the copper tube with silicone sealant, slipped it in and coated the outside of the joint with some sealant so that i could see that it wouldn't leak.
luqies
I found this
http://www.406coupeclub.org/Files/HowTo ... engine.pdf
Hope it helps others who will be doing this.
x 8191
luqies wrote:I found this
Good find and thanks for posting it here :D
Be aware though there is a second sealing surface below the cam ladder that can leak too and this procedure does not cover that one..
To do that one - basically the same sort of procedure - the camshafts need to be removed...
I'll be shortly doing it on my V6 Activa Project donor engine and if wanted, I'll do a photo-sequence of that aspect of the job and that, along with the one posted above, will make the job complete.
luqies
I got the bolt out eventually. The cover seems to be on very tight. Do I just pry it out now with a screwdriver?
@CitroJim that photo sequence would be of great benefit. Hopefully I wouldn need to do it but I have a feeling it could be the problem as I can't visually see any leaks from the cam cover...
Sent from my GT-N7100 using Tapatalk
x 1980
Hi
Yes they can be tight...esp with an unknown sticky adhesive type sealant used :)
It lifts a little then you have to slide it up and to the right to clear the black plastic cam belt covers
luqies
Bought a mallet to try and knock that cover off. It's like cemented on.
Will I need a torque wrench to put back cover?
x 1980
Being cast Alloy, take care you do not distort it
luqies
Its the plastic cover. This thing is so tough I kind of gave up.
