C5 Hydraulic pump flowrate
KP
x 27
Re: C5 Hydraulic pump flowrate
Unread post by KP »
the middle one looks almost alien!
thanks for the links VB but i dont think they would be upto the pressure im looking for as they all look to be low power units mainly for transfer of fluid between drums or such like :)
x 3298
Arrggghhhh! The Cybermen are coming!
x 2004
Unread post by Stickyfinger »
Come on KP.....what's this "project" all about ?
KP
x 27
Unread post by KP »
I'll spill when it's all working but could be a wee while ;) :D
dnsey
x 19
Unread post by dnsey »
Whatever you use, a rough calculation suggests that it will draw about 20A at 12V, so you'll need fairly hefty cable to minimise volt drop.
x 2004
KP wrote:I'll spill when it's all working but could be a wee while ;) :D
Not a good answer, I want to know I want to know I want to know I want to know I want to know I want to know I want to know I want to know I want to know
KP
x 27
Unread post by KP »
You can wait fella :D
x 2004
aggg.....another 10mins on the naughty step !
KP
x 27
Unread post by KP »
Ha ha ha more time on the naughty step means a longer wait.... ;) :p
BX
x 19
Unread post by BX »
That's the way to tell them KP. I hope it works as well for you as my one did when I built it last year. I did have a little trouble with clumping in the agglomeration but I overcame that. Your plan probably bypasses that stage. Good luck.
KP
x 27
Unread post by KP »
The pump and tank attached will be the highest part in the system so I'm hoping I can easily bleed it just through pumping it for a little bit and then leaving it a day or two and then same again over the course of a week or two :)
