thanks for the links VB but i dont think they would be upto the pressure im looking for as they all look to be low power units mainly for transfer of fluid between drums or such like
C5 Hydraulic pump flowrate
KP
- x 27
Re: C5 Hydraulic pump flowrate
the middle one looks almost alien!
- x 3296
Arrggghhhh! The Cybermen are coming!
- x 1996
Come on KP.....what's this "project" all about ?
KP
- x 27
I'll spill when it's all working but could be a wee while
dnsey
- x 19
Whatever you use, a rough calculation suggests that it will draw about 20A at 12V, so you'll need fairly hefty cable to minimise volt drop.
- x 1996
Not a good answer, I want to know I want to know I want to know I want to know I want to know I want to know I want to know I want to know I want to knowKP wrote:I'll spill when it's all working but could be a wee while![]()
KP
- x 27
You can wait fella
- x 1996
aggg.....another 10mins on the naughty step !
KP
- x 27
Ha ha ha more time on the naughty step means a longer wait....
:p
BX
- x 19
That's the way to tell them KP. I hope it works as well for you as my one did when I built it last year. I did have a little trouble with clumping in the agglomeration but I overcame that. Your plan probably bypasses that stage. Good luck.
KP
- x 27
The pump and tank attached will be the highest part in the system so I'm hoping I can easily bleed it just through pumping it for a little bit and then leaving it a day or two and then same again over the course of a week or two
