I came home from holiday on Monday with no problems and hav'nt used the car until today (Friday). Got in started the engine went to put my foot on the clutch an the pedal is flat to the floor.
So would this be the cable gone or could it be the actual clutch.
If its the cable how hard is it to fit a new one?
Thanks Pirate
Clutch C5 diesel
electronmirror
- x 30
Re: Clutch C5 diesel
What year, model and engine is it?
I had a feeling the C5 diesels used a hydraulic clutch not cable operation.
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
- x 5677
Mine is definitely hydraulic.
('03 2L HDi)
('03 2L HDi)
SaabC5
Yep, all hydraulic. Could be the slave cylinder which lurks under the battery area.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
Lighty
- x 34
Check the fluid level, it may have a small leak, once it's topped up, physically lift the pedal by hand & pump it, pedal will likely return.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
electronmirror
- x 30
Lighty,
Does that mean it's not a sealed system like the Xantia hydraulic clutch?
Ted
Pirate
Had a look and it is a hydraulic clutch couldnt find slave cylinder as didnt have any tools to remove engine covers, but i did see a small pipe (Like the vacuume tube which went from the carb to the distributor on old cars) that had perished at a joint, could that have anything to do with it?
Pirate
Pirate
- x 5677
There's a bleed nipple on the slave which seems to indicate it isn't sealed.electronmirror wrote:Lighty,
Never looked for the master cylinder/reservoir though.
Pirate
Update: Whent out for a look this morning checked the fluid level which was OK & dont know why but I pulled the clutch pedal up and it stayed there, so started the car and put it in gear and it pulled away ok, So I have no idea what the problem was. Can anyone identify What the vacuume tube that has perished is for? (See Picture Above)
Thanks Pirate
Thanks Pirate
- x 2004
Were those pipes connected together ?
have they been blocked off ?
what are the pipes connected to ?
where on the car did you take the photo?, its a bit close to be able to tell.
and lastly, do you have knowledge of Citroen suspension ?, just so we can judge for the technical content/advice in any of the reply's given.
( I know due to my "newness" to this myself, a big technically correct reply can be daunting
Pirate
I did think they were connected together at first but after having another look they go onto something screwed to the air box
Theres a couple of photos to show where the pipes are and what they connect to.
Pirate
Pirate
Reason: image links corrected.
Monkeyfeet
Close up is of a solenoid. One hose should go to the vacuum supply, other goes to one of the inlet hose control flaps?
I've disconnected all of mine (don't try this right now, another subject) but this is part of a system which bypasses the intercooler for dpf regenerations. If you've any other perished hoses it will cause gremlins, looks like it's worth checking.
As I said mine are removed so this is from memory, I stand to be corrected.
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
darbuck
- x 289
what you described with the clutch pedal suggests air in the slave or at least in the hydraulic line but the fact that it stopped suggests it may be a perished seal the slaves on the c5 are quite cheap off mister auto around 30 euro or £20 as for the pipes they are vacuum pipes as stated earlier by monkey feet.
Darren
