Clutch C5 diesel
Pirate
Clutch C5 diesel
Unread post by Pirate »
I came home from holiday on Monday with no problems and hav'nt used the car until today (Friday). Got in started the engine went to put my foot on the clutch an the pedal is flat to the floor.
So would this be the cable gone or could it be the actual clutch.
If its the cable how hard is it to fit a new one?
Thanks Pirate
electronmirror
x 30
Re: Clutch C5 diesel
Unread post by electronmirror »
What year, model and engine is it?
I had a feeling the C5 diesels used a hydraulic clutch not cable operation.
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
x 5672
Mine is definitely hydraulic.
('03 2L HDi)
SaabC5
Unread post by SaabC5 »
Yep, all hydraulic. Could be the slave cylinder which lurks under the battery area.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour) :wink:
Lighty
x 34
Unread post by Lighty »
Check the fluid level, it may have a small leak, once it's topped up, physically lift the pedal by hand & pump it, pedal will likely return.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
electronmirror
x 30
Lighty,
Does that mean it's not a sealed system like the Xantia hydraulic clutch?
Ted
Pirate
Had a look and it is a hydraulic clutch couldnt find slave cylinder as didnt have any tools to remove engine covers, but i did see a small pipe (Like the vacuume tube which went from the carb to the distributor on old cars) that had perished at a joint, could that have anything to do with it?
Pirate
x 5672
electronmirror wrote:Lighty,
There's a bleed nipple on the slave which seems to indicate it isn't sealed.
Never looked for the master cylinder/reservoir though.
Pirate
added picture above
Pirate
Update: Whent out for a look this morning checked the fluid level which was OK & dont know why but I pulled the clutch pedal up and it stayed there, so started the car and put it in gear and it pulled away ok, So I have no idea what the problem was. Can anyone identify What the vacuume tube that has perished is for? (See Picture Above)
Thanks Pirate
x 1995
Unread post by Stickyfinger »
Were those pipes connected together ?
have they been blocked off ?
what are the pipes connected to ?
where on the car did you take the photo?, its a bit close to be able to tell.
and lastly, do you have knowledge of Citroen suspension ?, just so we can judge for the technical content/advice in any of the reply's given.
( I know due to my "newness" to this myself, a big technically correct reply can be daunting :) )
Pirate
I did think they were connected together at first but after having another look they go onto something screwed to the air box
Theres a couple of photos to show where the pipes are and what they connect to.
Pirate
Reason: image links corrected.
Monkeyfeet
(Donor 2022)
Unread post by Monkeyfeet »
Close up is of a solenoid. One hose should go to the vacuum supply, other goes to one of the inlet hose control flaps?
I've disconnected all of mine (don't try this right now, another subject) but this is part of a system which bypasses the intercooler for dpf regenerations. If you've any other perished hoses it will cause gremlins, looks like it's worth checking.
As I said mine are removed so this is from memory, I stand to be corrected.
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
darbuck
x 289
Unread post by darbuck »
what you described with the clutch pedal suggests air in the slave or at least in the hydraulic line but the fact that it stopped suggests it may be a perished seal the slaves on the c5 are quite cheap off mister auto around 30 euro or £20 as for the pipes they are vacuum pipes as stated earlier by monkey feet.
Darren
