Back together again. Belt on with about 45deg twist. Routed to the Haynes SOHC with aircon. Made sure floating sprocket on Crank was centred with 2 pins.
Started up fine. Noisy! It is the bottom pully I think. The belt is undulating badly, so something is eccentric. Would poor timing cause belt to jump up and down? I only put a new one on as I was going in there . The old one was ok.
Tomorrow I will put the old one back on. See how that goes and will update.
Running rough after cambelt change
lexi
- x 134
Re: Running rough after cambelt change
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
lexi
- x 134
Old Crank pulley back on............Donk is back in business
New crank pulley was cheapo. It could be manufacturing fault or more likely the wrong one for car. Same dimensions but there are so many other factors like weight etc. I knew there was nothing wrong with original pulley, so I thought I could not justify a £100 item.
I will get back to supplier.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 8253
Is that with the new belt Lexi?
daviemck2006
- x 496
That's a good donk!
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
lexi
- x 134
New belt Jim. The way I worded in last post ,it looked like I was putting old belt back on.........it was old crank pulley back on I meant.
The Donk knew better Davie..........it was back on to Blackpool beach for it, if there was any more nonsense!
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
daviemck2006
- x 496
Oh no! A trip to Blackpool beach would fear anyone or anything into behaving [emoji12] [emoji13] [emoji3]
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
