Running rough after cambelt change
lexi
x 133
Re: Running rough after cambelt change
Unread post by lexi »
Back together again. Belt on with about 45deg twist. Routed to the Haynes SOHC with aircon. Made sure floating sprocket on Crank was centred with 2 pins.
Started up fine. Noisy! It is the bottom pully I think. The belt is undulating badly, so something is eccentric. Would poor timing cause belt to jump up and down? I only put a new one on as I was going in there . The old one was ok.
Tomorrow I will put the old one back on. See how that goes and will update.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
lexi
x 133
Old Crank pulley back on............Donk is back in business :lol:
New crank pulley was cheapo. It could be manufacturing fault or more likely the wrong one for car. Same dimensions but there are so many other factors like weight etc. I knew there was nothing wrong with original pulley, so I thought I could not justify a £100 item.
I will get back to supplier.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 8436
Is that with the new belt Lexi?
daviemck2006
x 485
Unread post by daviemck2006 »
That's a good donk!
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
lexi
x 133
New belt Jim. The way I worded in last post ,it looked like I was putting old belt back on.........it was old crank pulley back on I meant.
The Donk knew better Davie..........it was back on to Blackpool beach for it, if there was any more nonsense! :lol:
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
daviemck2006
x 485
Oh no! A trip to Blackpool beach would fear anyone or anything into behaving [emoji12] [emoji13] [emoji3]
Peugeot boxer 2016
In the family
