Xantia Remote Batteries.
Chlorate
Hello all, I'm sure this is a common question but I couldn't find the answer.
Not long ago my plip stopped working, finally found some new batteries for them, however neither will lock or unlock the car. What have I missed?
Cheers,
Alex
Cheers,
Alex
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police
previously:
- x 3296
Re: Xantia Remote Batteries.
IIRC what you do is to unlock the car manually, put the key into the ignition, turn the key to the 'M' position, and then press one of the buttons on the fob. That should re-introduce the fob to the car.
- x 1995
Chlorate
Perfect, nice one James
both working now.
previously:
previously:
- x 3296
Glad I could help (and that my memory was correct).
Old-Guy
- x 26
N.B. This is the procedure for Xantia II RC remotes. The original Xantia IR remotes are re-programmed differently and in my experience, don't usually need re-programming if you just fit new batteries.
- x 1995
And I can confirm that my key remote does not work despite the new batteries and trying the above this morning....
(1997 S1 car)
elma
- x 284
Pull the board out and check the switches and diode don't have any broken connections.
- x 1461
While looking for something else, I found a Mk1 Xantia remote plip which I am 95% sure is in working condition. You can have it if you like.Stickyfinger wrote:And I can confirm that my key remote does not work despite the new batteries and trying the above this morning....(1997 S1 car)
MikeT
- x 232
IIRC MKI's use infrared so you have to make sure there's a clear line of sight to the dome (or adequate reflective angles) when re-synching. Easy way to check remote is emitting, is use a digi-cam - they show the infra red pulses when buttons are pushed. If no show, then strip the casing off and do as elma suggests.
Old-Guy
- x 26
Alasdair, specially for you, there's a new wiki (Mk1) IR Remote Repair & Re-Sync
OnlineCitroJim
- x 8407
One of yours I take it GuyOld-Guy wrote:Alasdair, specially for you, there's a new wiki (Mk1) IR Remote Repair & Re-Sync
Old-Guy
- x 26
Quickly re-formatted. Took a bit longer to sort the pictures as I'd originally been a bit lazy and cropped/re-sized them within OO-Writer, so when I copied the images just now, they got uploaded at original size/shape
Now sorted, wiki includes pictures for repair.
- x 1461
And I just added a couple of sentences...
OnlineCitroJim
- x 8407
xantia_v6 wrote:And I just added a couple of sentences...
