Xantia Remote Batteries.
Chlorate
Unread post by Chlorate »
Hello all, I'm sure this is a common question but I couldn't find the answer.
Not long ago my plip stopped working, finally found some new batteries for them, however neither will lock or unlock the car. What have I missed?
Cheers,
Alex
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
x 3296
Re: Xantia Remote Batteries.
IIRC what you do is to unlock the car manually, put the key into the ignition, turn the key to the 'M' position, and then press one of the buttons on the fob. That should re-introduce the fob to the car.
x 1996
Unread post by Stickyfinger »
Well that help me :)....cheers
Chlorate
Perfect, nice one James :) both working now.
previously:
x 3296
Glad I could help (and that my memory was correct).
Old-Guy
x 25
Unread post by Old-Guy »
N.B. This is the procedure for Xantia II RC remotes. The original Xantia IR remotes are re-programmed differently and in my experience, don't usually need re-programming if you just fit new batteries.
x 1996
And I can confirm that my key remote does not work despite the new batteries and trying the above this morning....:) (1997 S1 car)
elma
x 284
Unread post by elma »
Pull the board out and check the switches and diode don't have any broken connections.
x 1459
Unread post by xantia_v6 »
Stickyfinger wrote:And I can confirm that my key remote does not work despite the new batteries and trying the above this morning....:) (1997 S1 car)
While looking for something else, I found a Mk1 Xantia remote plip which I am 95% sure is in working condition. You can have it if you like.
MikeT
x 232
Unread post by MikeT »
IIRC MKI's use infrared so you have to make sure there's a clear line of sight to the dome (or adequate reflective angles) when re-synching. Easy way to check remote is emitting, is use a digi-cam - they show the infra red pulses when buttons are pushed. If no show, then strip the casing off and do as elma suggests.
Old-Guy
x 25
Alasdair, specially for you, there's a new wiki (Mk1) IR Remote Repair & Re-Sync
x 8397
Old-Guy wrote:Alasdair, specially for you, there's a new wiki (Mk1) IR Remote Repair & Re-Sync
One of yours I take it Guy :-D It's absolutely excellent!
Old-Guy
x 25
Quickly re-formatted. Took a bit longer to sort the pictures as I'd originally been a bit lazy and cropped/re-sized them within OO-Writer, so when I copied the images just now, they got uploaded at original size/shape :shock:
Now sorted, wiki includes pictures for repair.
x 1459
And I just added a couple of sentences...
x 8397
xantia_v6 wrote:And I just added a couple of sentences...
:-D
