Lower (rear) Ram bush
- x 1982
My lower Ram bush needs changing, just wondering if the lower Pin needs changing at the same time ? Good Practice to change it ?
They are not yet listed as NFP on Citroen Service BTW
( I have not split this joint yet so cannot check for damage to it....)
DickieG
- Monaco's youngest playboy
- x 38
Re: Lower (rear) Ram bush
The bush might still be available but have you looked at the price? It used to be £15 then after being out of stock the new price was £150!
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 1982
Its not listed (that I can find).
I can get a two part mold turned for that which allows a two bonded bush to be poured.
- x 3283
Wait until CitroJim sees this thread. He knows how to make them. Try this;
http://www.eastment.net/rambush/index.htm" onclick="window.open(this.href);return false;
- x 1982
He has now offered...he is a star that boy !
I will be talking to two people next week to see if I can get some OEM style ones made in a batch.
DHallworth
- x 163
These bushes are the same as the steering rack bush on a Peugeot 405
I've got one in a bag at my folks, I'll get the part number off it tomorrow for you Sticky. They're only £9 from Peugeot too
Edit... Just found the part number... 405910
There's also a bush from a Xsara Picasso which is the same. This is the one I ordered. Here's pictures of it here...
Part number for this one is 405911. Currently retails at £11.59, as opposed to the £150 odd they want for the Activa ram bush. This is the part number of the one I purchased. It looks identical to the old bush. I've not yet fitted it as I didn't find out about this one until after I'd turned mine from Nylon66.
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 1982
well well well, has Jim seen these ?
How do you regarded the harder bush to the OEM one on before ?
I think I will fit it up with the one Jim is turning but I will get a couple of these if for nothing else but to use as a pattern for a Poly set as I am a little uncertain of the advantage of having a solid bush in that joint. Got to go to Citroen later in the week for parts so I will pick up these from the PugShop on the way.
Cheers for that, nice to have options with suspension...I am horrid fussy about it
Comments Jim ?
Comments Jim ?
- x 8220
I'm now reminded that David told me about these ages ago but it had fallen out of my memory!Stickyfinger wrote: Comments Jim ?
Best get a stock in
- x 1982
How do you feel about the stiff nylon bush vrs this softer one, do you think it causes changes to comfort/noise/ram action ?
It seems strange to me to have a metal ball joint at one end and a non-flexible on at the other, does this not send the roll bar shock loads to the ram without some form of damping/isolation ?
Would it not cause problems with the Ball Joint socket being stressed/damaged ?
- x 8220
I have never heard of any problems running my type of hard nylon one Sticky...
DHallworth
- x 163
I've had one of Jim's type of Nylon bushes in mine for a while now. I turned mine on the lathe up here from a rod of Nylon66.
It certainly made my car a lot quieter as my old bush fell apart when removed. I've not noticed any ill effects running the new one anyway
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 1982
OK Chaps, I will take your advice, thanks.
err.....where can I find the torque values for rebuilding ?....in fact is there anything that lists them for the Xantia in general on the net ?
- x 8220
I can supply most of what you want in torque figures Sticky, if the Haynes manual doesn't tell you. It’s actually quite good for that!
- x 1982
LOL...Haynes, who would of thunk it......I use it in strips with an added wet wipe.CitroJim wrote:I can supply most of what you want in torque figures Sticky, if the Haynes manual doesn't tell you. It’s actually quite good for that!
Was there ever a "Citroen Technical" book on it ?
- x 8220
Stickyfinger wrote: LOL...Haynes, who would of thunk it......I use it in strips with an added wet wipe.
There was a French 'Revue Technique' for the Xantia.. Basically the French take on Hayes but arguably better. I think I may have a PDF of it somewhere..Stickyfinger wrote:Was there ever a "Citroen Technical" book on it ?
Your best bet is to look out for a set of genuine Xantia manuals. They come up on ebay every now and again.. The full set is 7 or 8 A4 binders and takes up a lot of space... At least four of the volumes are wiring diagrams!
