High guys....quick ??
Speedo, from KMPH -2- MPH....
OK, can the Brit 2ltr speedo replace the KMPH Speedo or will I have to use the Brit V6 Speedo to get the correct calibration ?
V6 Speedo.. KMPH - MPH
- x 1980
DHallworth
- x 163
Re: V6 Speedo.. KMPH - MPH
The Brit 2 litre speedo should work without fault. When my car was converted from the TCT to the V6, the speedo wasn't changed.
I wonder if the car will have a hissy fit if the mileage on the clusters is different?
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 1980
Hummmmm ya bugger....had not thought of that ....well trial and error then or work a way to switch the face plate/or/decal
- x 1410
The distance counter on a mk1 is mechanical, so the car does not care.
DHallworth
- x 163
Of course! I'd forgotten it was a Series 1 that Sticky is converting!
My bad!
I'd imagine that the TCT speedo will still work, however, if you're going to the hassle of stripping it out, I'd have a peek and see if you can match the mileages. Just transferring the fascia won't work I wouldn't imagine as the milometer will still be recording km spinning round but the speedo would be in mph. I'd use the TCT one if it's a Series 1 and then just try and match the mileage. Does the Series 1 Activa still have Oil and Water temperature gauges?
David.
My bad!
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 1980
DHallworth wrote:Of course! I'd forgotten it was a Series 1 that Sticky is converting!
My bad!
David.
Ahhh ya buggoor...had me for a little bit there
Yes David...a S1 with wheels init....finally a use for [init] ..AliG will be proud.
Miles or Km recording is not a problem, all I would like is MPH showing on the needle
How would i change the millage wheels to show correct equivalent on the replaced MILE counter ?
