V6 Speedo.. KMPH - MPH
x 1996
Unread post by Stickyfinger »
High guys....quick ??
Speedo, from KMPH -2- MPH....
OK, can the Brit 2ltr speedo replace the KMPH Speedo or will I have to use the Brit V6 Speedo to get the correct calibration ?
DHallworth
x 167
Re: V6 Speedo.. KMPH - MPH
Unread post by DHallworth »
The Brit 2 litre speedo should work without fault. When my car was converted from the TCT to the V6, the speedo wasn't changed.
I wonder if the car will have a hissy fit if the mileage on the clusters is different?
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 1996
Hummmmm ya bugger....had not thought of that ....well trial and error then or work a way to switch the face plate/or/decal
x 1459
Unread post by xantia_v6 »
The distance counter on a mk1 is mechanical, so the car does not care.
DHallworth
x 167
Of course! I'd forgotten it was a Series 1 that Sticky is converting!
My bad!
I'd imagine that the TCT speedo will still work, however, if you're going to the hassle of stripping it out, I'd have a peek and see if you can match the mileages. Just transferring the fascia won't work I wouldn't imagine as the milometer will still be recording km spinning round but the speedo would be in mph. I'd use the TCT one if it's a Series 1 and then just try and match the mileage. Does the Series 1 Activa still have Oil and Water temperature gauges?
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 1996
DHallworth wrote:Of course! I'd forgotten it was a Series 1 that Sticky is converting!
My bad!
David.
Ahhh ya buggoor...had me for a little bit there :)
Yes David...a S1 with wheels init....finally a use for [init] ..AliG will be proud.
Miles or Km recording is not a problem, all I would like is MPH showing on the needle
How would i change the millage wheels to show correct equivalent on the replaced MILE counter ?
