Mr Chris Salters new acquasition
Dedicated to owners of Citroen GS and GSA models.
Northern_Mike
Re: Mr Chris Salters new acquasition
I'll tell you what I've got this weekend. Whatever we have that our kid doesn't want I shall steal and bring to you.
Are you up for some DRK-ing? I have a 1397cc Gordini motor and 5 speed box that'll fit :-) rebuilt....
Vorsprung berk Technik
x 8391
The_Hairdresser wrote: Are you up for some DRK-ing? I have a 1397cc Gordini motor and 5 speed box that'll fit :-) rebuilt....
Is this potentially good news on the DRK front Mike?
x 94
Unread post by citronut »
i had a blinding flash in the night,
its blatently obvious really,
as it had one of the three manifold block bolts already sheared of on coming to me, which i had not spotted in situe,
with the hot spot pipes connected the one on the side of the manifold were the sheared bolt was was pulling on the flange plate, so causing an induction leak and with the hot spot pipes disconnected the plate relaxed so closed the gap,
this will cause all 4 cylinders to be struggling to get the required go go juice, as the manifold block is one open chamber,
i will know later today once a add more go go juice with the hot spots re/attached
Regards, malcolm.
Mothman
x 4
Unread post by Mothman »
Well done bud, fingers crossed that your blinding flash isnt just a senior moment!! Here are some more piccies of the old girl!!
Andy
1980 GSA C-Matic
1984 Citroen BX19RD
1985 Citroen BX19RD
1985 Citroen BX19TRD saloon
1986 Citroen BX19RD Automatic
1988 Citroen BX19TRS saloon
1990 Citroen BX16TGS Estate
1991 Citroen BX19TZD Estate
1992 Citroen BX19TXD Estate
1993 Citroen BX17TZD Estate
x 8391
Fingers crossed Malcolm [-o<
That numberplate is appropriate. It almost says 'HELP'
x 94
:rofl2: :rofl2: :rofl2:
Regards, malcolm.
x 94
sorted well at least got to the bottom of the problem/or maybe there were two or more,
got her going again this afternoon, reconnected the hot spot pipes and no go again, so i disconnected the front to back exhaust pipe from the Y piece ( front end of front to rear pipe ),
and guess what even now with the hot spot pipes connected she starts revs and runs, i did record the wonderful sound on my mob phone, so how do i post that on here
Regards, malcolm.
x 8391
Progress is being made Malcolm =D>
Mothman
x 4
So it was a senior moment last night then? These are getting more and more frequent!! Just a blocked exhaust pipe!!
Andy
1980 GSA C-Matic
1984 Citroen BX19RD
1985 Citroen BX19RD
x 94
here is Chris Salters blockage
https://www.dropbox.com/sh/cc93yzfkv51l ... X_4La?dl=0" onclick="window.open(this.href);return false;,
after cutting sections of the front to rear exhaust pipe the above came out from a section about 3/4's of the way towards the back box end of this pipe
and here is what it sounds like
https://www.dropbox.com/s/evxuxpgbyb1pq ... d.m4a?dl=0" onclick="window.open(this.href);return false;
Regards, malcolm.
x 94
Mothman wrote:So it was a senior moment last night then? These are getting more and more frequent!! Just a blocked exhaust pipe!!
Andy
nah i dont know what your talking about, anyway who are you what do you want :twisted: :roll: #-o :-D :lol: :rofl2: :rofl2:
although i believe there musterd bin an induction leak as well as the blocked exhaust
Regards, malcolm.
x 94
DOH
the sound recording link above dont seem to work
Regards, malcolm.
macplaxton
Unread post by macplaxton »
Does now.
Mothman
x 4
Ansome Malc, well done in sorting the old girl bud, Chris will be pleased.
GS Rules OK?
Andy
1980 GSA C-Matic
1984 Citroen BX19RD
1985 Citroen BX19RD
x 94
and underneath is almost immaculate, no tin worm in sight, the floor pans have just had the rubberised coating scrapped, were the scrap yard that the previous owner to Chris rescued her from, used a FFFFFFFFF ORK!!!!! lift to move her about good to see there is no metal damage from this,
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
even the rear sub frame is very very good ( no tin worm again ), just one lower edge/lip of this has been rolled over, but i think this will have been from the flat bed she was delivered to me on
Regards, malcolm.
