2009 C5 handbrake error message
DickieG
- Monaco's youngest playboy
- x 38
Re: 2009 C5 handbrake error message
I'd start with clearing all the faults then carry out a BSI reset and see what happens from there, as mentioned it appears that there's been a current issue that has upset a number of items, if the fault reoccurs then I'd investigate further rather than get too involved spending hours looking for something that is no longer there.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
osx
- x 15
Sticky cleared all the faults but haven't carried out the BSI reset yet - need to write everything down and do some test runs first!
C5 X7 Exclusive 2.0 HDi Auto
osx
- x 15
It was the b#$£#4%$ brake switch. Replaced it and everything is fine now.
- x 1987
Great...FIXED but how did you find out it was the switch ?
osx
- x 15
Tried the cheapest option first
Saying that, I would feel more confident once nothing comes up after a week of driving.
- x 1987
Ahhh, a good guess then, good hit
..as said, pop in any time and we can clear them all now.
- x 1480
Ours got better for a while after I changed the brake light switch, but then it deteriorated again. Given the faults on lack of speed info to the ECUs, I suspect you will be after a replacement board soon......
- x 1987
Richard, is there any way to check it to see/what to look for on a failing board ?
- x 1480
Not as far as I know - the fact that there is a loss of coms between ECUs seems to be the smoking gun. I read a few posts about it in various places, but although quite a few had been changed, there was nothing obvious in failure. It might just be a dodgy chip on the board.
osx
- x 15
If its the fuse box I might as well keep an eye for one and have it as a backup.
osx
- x 15
Did another diagnostic today
U1213 - fault in the vehicle speed information received by the CAN from the ABS or ESP ECU
U2005 - triggering (vehicle speed receipt anomaly)
nothing with the handbrake this time
- x 1987
U1212 @ Is not the AntiLock/ESP system the one that controls/actions the Anti-roll-Back system....which is the original fault message. ??osx wrote:Did another diagnostic today
osx
- x 15
Cleared them all and will do another diagnostic tomorrow. Tried to do a BSI reset but chickened out half way when the window started going up while I was outside the car with keys on the ignition.
- x 1987
LOL, that should not happen...
DickieG
- x 38
More than likely just the anti trap activated, let it sort itself out and away you go.osx wrote:Cleared them all and will do another diagnostic tomorrow. Tried to do a BSI reset but chickened out half way when the window started going up while I was outside the car with keys on the ignition.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
