2009 C5 handbrake error message
DickieG
Monaco's youngest playboy
x 33
Re: 2009 C5 handbrake error message
Unread post by DickieG »
I'd start with clearing all the faults then carry out a BSI reset and see what happens from there, as mentioned it appears that there's been a current issue that has upset a number of items, if the fault reoccurs then I'd investigate further rather than get too involved spending hours looking for something that is no longer there.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
osx
(Donor 2022)
x 15
Unread post by osx »
Sticky cleared all the faults but haven't carried out the BSI reset yet - need to write everything down and do some test runs first!
C5 X7 Exclusive 2.0 HDi Auto
osx
(Donor 2022)
x 15
It was the b#$£#4%$ brake switch. Replaced it and everything is fine now.
x 1996
Unread post by Stickyfinger »
Great...FIXED but how did you find out it was the switch ?
osx
(Donor 2022)
x 15
Tried the cheapest option first ;-)
Saying that, I would feel more confident once nothing comes up after a week of driving.
x 1996
Ahhh, a good guess then, good hit
..as said, pop in any time and we can clear them all now.
x 1489
Ours got better for a while after I changed the brake light switch, but then it deteriorated again. Given the faults on lack of speed info to the ECUs, I suspect you will be after a replacement board soon...... :roll:
x 1996
Richard, is there any way to check it to see/what to look for on a failing board ?
x 1489
Not as far as I know - the fact that there is a loss of coms between ECUs seems to be the smoking gun. I read a few posts about it in various places, but although quite a few had been changed, there was nothing obvious in failure. It might just be a dodgy chip on the board.
osx
(Donor 2022)
x 15
If its the fuse box I might as well keep an eye for one and have it as a backup.
osx
(Donor 2022)
x 15
Did another diagnostic today
U1213 - fault in the vehicle speed information received by the CAN from the ABS or ESP ECU
U2005 - triggering (vehicle speed receipt anomaly)
nothing with the handbrake this time
x 1996
osx wrote:Did another diagnostic today
U1212 @ Is not the AntiLock/ESP system the one that controls/actions the Anti-roll-Back system....which is the original fault message. ??
osx
(Donor 2022)
x 15
Cleared them all and will do another diagnostic tomorrow. Tried to do a BSI reset but chickened out half way when the window started going up while I was outside the car with keys on the ignition.
x 1996
LOL, that should not happen...
DickieG
x 33
osx wrote:Cleared them all and will do another diagnostic tomorrow. Tried to do a BSI reset but chickened out half way when the window started going up while I was outside the car with keys on the ignition.
More than likely just the anti trap activated, let it sort itself out and away you go.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
