[1996 Synergie] What's this blue lamp on my dashboard?
kenbw2
(Donor 2017)
x 24
Unread post by kenbw2 »
It's on with headlights and sidelights, but isn't the usual green one - that's on the other side. It sort of flickers, but is mostly on.
And while I'm at it, what's the little dial at the bottom of my rev meter?
x 3298
Re: [1996 Synergie] What's this blue lamp on my dashboard?
The blue light is for main beam (the brightest setting of the headlights), while the gauge looks like it might be related to the oil.
Northern_Mike
kenbw2 wrote:Image
The blue lamp is for the high-beam setting for the headlights :shock:
The gauge is the oil level.
x 94
Unread post by citronut »
as others have said the only blue light should be for main beam,
the oil level gauge should indicate the oil level as the ignition is switched on a few seconds after the engine is running it should go out
Regards, malcolm.
kenbw2
(Donor 2017)
x 24
The blue light isn't for main beam, that appears separately on the right and looks like a standard one. As I mentioned, that blue light comes on just with sidelights
vborovic
Locked user account
x 40
Unread post by vborovic »
Not familiar with the Synergie, but the proper (and only) main beam icon/signalization should be:
This looks more like the sidelight icon, but the color is off, it should be green ... either someone changed the bulb color for it, or it means something totally different ...
EDIT: I've found an image of a Synergie dash, it should look more or less like this:
Meaning, if the positions are correct, your blue sidelamp icon is actually the front fog lamp?
x 94
as vborovic says maybe someone has replaced the bulb or lens with a blue one,
the only blue light i have ever seen on a car dash is only for main beam,
Regards, malcolm.
Richard_C
(Donor 2026)
x 239
Unread post by Richard_C »
On my 1998 diesel SX, with foglights, the layout is:
No extra light for sidelights, the dashboard illumination comes on
To the right of the speedometer there is a pair of lights, green and blue, indicating dipped or main beam headlights and mutually exclusive.
To the left of the Rev counter there is a pair of lights, green and Amber, for the front and rear fog lights, both can be on together.
looking at an old French manual, if the vehicle does not have front fog lights one of the left hand pair is used to show sidelights on.
The oil level gauge which only registers accurately before you start the engine, is in the bottom of the Rev counter, with a symbol like an upturned J, with drips....
The centre display, shown in the picture from viborovic, has an exterior temperature indicator or a trip computer on later/better equipped versions.
Richard_C
x 2007
Unread post by Stickyfinger »
Lights and symbols are ISO/EN Standard...all over the world
http://www.iso.org/iso/home/store/catal ... 0&ICS3=20&
The ONLY other blue light I have seen on a dash is the "Water Cold" light on the Kia.....but it does not have a water gauge, so needs a light :)
Zelandeth
x 1608
Unread post by Zelandeth »
Symbol definitely looks like the "light bulb" one often used for sidelights, though it would usually be green. Wonder if someone has put a blue bulb in for some reason.
Current fleet:
07 Volvo V70 SE D5, 89 Ford Thunderbird, 85 Sinclair C5, 84 Trabant 601S, 73 AC Model 70, 62 Rover 110.
Harlequin
x 24
Unread post by Harlequin »
from my handbook:
it says ` sidelamps see page 44`
x 94
can you add the page that says/shows what all the warning/lighting lamps are for?????
Regards, malcolm.
Harlequin
x 24
Harlequin
x 24
Harlequin
x 24
