What exactly is my C5 Driveshaft gaiter?
begins
Unread post by begins »
Hi all,
I wanted to replace my C5 (Year 2007 2.0L Petrol) driveshaft inner gaiter (The rubber cover). So I sent the picture of the worn rubber joint as attached to the dealer:
But the dealer given me something that is too small to fit:
The dealer assured me that this rubber cover is certainly meant for my model. Unless, I'm able to tell them the exact part number, they are unable to allow an exchange.
Can any kind souls here advise me what should be the correct part number of these rubber cover?
Thank you very much.
Regards,
hamster99
Re: What exactly is my C5 Driveshaft gaiter?
Unread post by hamster99 »
Are you sure that's a driveshaft?
One of the pictures shows it as the steering track rod.
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
x 3302
I agree, the third photo shows a track rod. A drive shaft is a lot thicker.
x 2941
The one supplied is for the RH drive shaft the one you need is for the LH, they're much different.
x 1240
Unread post by Peter.N. »
Looks like the inner end of the drive shaft, that will be a different gaiter to the CV joint.
x 1485
Do you know the part number supplied? There appears to be more than one type - if you post up the chassis number of your car, and let us know which side, I can look up the correct part number.
begins
RichardW wrote:Do you know the part number supplied? There appears to be more than one type - if you post up the chassis number of your car, and let us know which side, I can look up the correct part number.
Hi Richard,
Sorry for the later reply. The number is VF7**************[VIN obfuscated, can be read by forum staff].
Thank you very much for the kind assistance.
Regards,
x 1485
There's only one kit listed for both sides:
04
3287 81
02 DRIVESHAFT GAITER KIT
AXLE SIDE ( MARK GAITER 9620994080 )
begins
RichardW wrote:There's only one kit listed for both sides:
04
3287 81
Thank you very much for your help.
By the way, just a quick one, do you also know what Spark Plug specification should I be using on my C5?
Regards,
Clogzz
x 40
Unread post by Clogzz »
The spark plug type is written on the label inside the front of the bonnet.
begins
04
3287 81
Oh dear, in the end I bought the wrong part. It should have been 9647779180 instead of 9620994080. 9620994080 cannot be fitted to the drive shaft.
Anyway, I'm exchanging the 9620994080 for something else.
Regards,
begins
Clogzz wrote:The spark plug type is written on the label inside the front of the bonnet.
Can't find any..
Thanks, anyway.
Regards,
