They are quite different from an XM or Xantia Jim, you should be fine with a trip out in oneCitroJim wrote:That Franklin, is always the risk with me. Hence why I'll never take up the offer of a drive (or even a ride) in a C6!!Citroening wrote:All I can say Jim is that good job you politely turned down dads offer for you to drive the Series 1 CX Prestige back from Stowe Gardens to Little Horwood last year - you'd probably be a CX owner now...!![]()
My XM V6 ES9
Citroenmad
- x 110
Re: My XM V6 ES9
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 5629
Re: My XM V6 ES9
They are very enticing though!
Citroenmad
- x 110
Re: My XM V6 ES9
Very truemyglaren wrote:They are very enticing though!
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Chris570
- x 36
Re: My XM V6 ES9
Come to CXM, i owe you a pint.Rattiva_Mike wrote:My XM Estate had what I thought was a rumbling wheel bearing. Turned out to be a knackered tyre. Had the same on a Golf GTi too. Might be worth a quick check/swap of wheel just to see. It sounded *exactly* like a knackered bearing.Chris570 wrote:Are all rear wheel bearings the same then for XM's?Deanxm wrote:Glad its going well and your happy with her Chris, wheel bearings are available, im sure gsf done them but i guess now they dont, loads on ebay though, Here's one.
Look forward to seeing you both at cxm.
D
I think they are according to service citroen
I have my cruise control working again
Oh and the XM is back on form, refused to start this evening after driving it 15 miles, my fault i suppose, it was driven those 15 miles with the heated rear window on and lights on and the heating on and before that it was engine off, ignition on while testing the cruise circuits.
We will get there, i'm now only a few items away from a 100% functional XM and I WILL do it (how long it will stay at 100% i've no idea though)
Oh and i did have 2 lines of pixels out on the left hand display, i now only have 1 line out. I do like this car.
It's been a struggle but the fact i keep going with it should say plenty. It's a lovely car and I Love it.
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
Chris570
- x 36
Re: My XM V6 ES9
New Receiver/Drier fitted this evening and i'm due to have an aircon guy come out to it tomorrow to leak test and hopefully fill with oil gas and dye
I also re-initialised the autobox and went for a drive, an awful lot smoother now
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
- x 8241
Re: My XM V6 ES9
Cool
Just in time for the end of summer
Is that the first time you've done it Chris?
Great stuffChris570 wrote: I also re-initialised the autobox and went for a drive, an awful lot smoother now
Chris570
- x 36
Re: My XM V6 ES9
I'd rather the system was full of gas than empty with moisture in... and also demisting
It's the first time i've done that and the difference is astounding
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
Chris570
- x 36
Re: My XM V6 ES9
update time.
Aircon regassed and refilled with oil and the UV dye. Compressor refused to kick in at first, had a wiggle of the relays by the fusebox et voila cold air. I've since cleaned up the contacts on all the relays down there and touch wood the aircon is still working as and when i want it and bloody hell it's good, I thought the HDi was good but this is better.
I have an occassional issue with starting, sometimes the car refuses to turnover, sounds like a dead battery but it's actually the starter solenoid not clicking in, a few goes and normality is resumed.
The front has been ruddy hard since i've had the car so i changed the front centre sphere (the bracket has been bent in the past so the sphere touches the rack, not funny) but this made no difference, so I'll be looking at the electrical side now i know it has a good sphere attached....
the cruise is working perfectly and on the last tank of fuel i got 31mpg, I really must get the LPG working.
That's all for now
That's all for now
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
red_dwarfers
- x 58
Re: My XM V6 ES9
I do miss air con! Good to hear the aircon didn't kick up too much fuss!
Kev
'19 C4 Cactus 130 Flair
- x 8241
Re: My XM V6 ES9
You're preaching to the converted there ChrisChris's Signature wrote:1999 XM V6 S2 - Fantastic, well worth the agro
Went out in mine today for a trip to the nearest purveyor of LPG. Feeling like poo but a ride in an XM is positively therapeutic
bxzx16v
- x 34
Re: My XM V6 ES9
I can't wait to see your Xm Chris at the Cxm , I do like Xm's
Mark
Mark
Chris570
- x 36
Re: My XM V6 ES9
I've got a lovely juddering under braking from the XM and also vibration coming from the o/s/f when you turn into a left hand corner. i suspect tracking as it's been done very badly. possibly this weekend i'll get the Xm down to be tracked and with any luck i'll fill her up with LPG...........
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
- x 8241
Re: My XM V6 ES9
So how will that help with the juddering then? Ballast?Chris570 wrote: i'll fill her up with LPG...........
Come and have it done by the mob near my gaff and you can pop my cat on while you're waiting Chris
Chris570
- x 36
Re: My XM V6 ES9
Tracking shouldnt take more than 30 mins though, what will i do for the other 20?CitroJim wrote:So how will that help with the juddering then? Ballast?Chris570 wrote: i'll fill her up with LPG...........
I think i've found a supplier of an ECU for me so i should be (literally) running on gas soon
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
- x 8241
