Dean's Activa/XM/V6 and now Talbot blog
x 8350
Re: Dean's Activa/XM blog
Deanxm wrote:Now of course i have a perminant abs fault though :roll: :lol:
'Course you do. It's an Activa isn't it :roll: :lol:
Deanxm
x 87
Unread post by Deanxm »
:lol: but of course, im wondering if its going to be best to break out the avo now or just be lazy and see if i can get her lexia'd at cxm? i think the later may be better at the moment.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
x 8350
Deanxm wrote::just be lazy and see if i can get her lexia'd at cxm?
Definitely the best option Dean :) It's a lot less faffing about than using an AVO... Hopefully it's just a loose plug following the work done...
Deanxm
x 87
The light came up before work started Jim, the spraying down with lhm at high pressure must be the culprit or it could be pure chance, I think your right though its going to be a lot less hassle to have it gone over with a lexia.
D
XM Prestige PRV6 92
Deanxm
x 87
Forgot to update this with the real problem i found, as reported she was running fine but on monday i noticed the pump straining, sounded very clackety and the belt was squeeking slightly so i popped the pressure tester on again and i was getting just under 180bar as i was sunday after removing 1 shim from cut out side of the regulator. Opening the 12mm bleed a little on the reg to get it to cycle at a fast enough rate let the pressure guage bounce between 140bar and again a smidge under 180bar which is just about spot on but the pump was not straining, then all of a sudden the pressure guage went off the scale at 230bar :shock: , i opened the bleed up a bit more and the preessure fell away, then doing the bleed back up a bit it sat there bouncing between 140 and 180 ish again for around 2 minutes.........................
Took the decision to pull the reg off again and get it on the bench, this time i didnt just take the bung and cap off to extract the shims but took the springs out and found the smaller of the two had snapped and was getting wedged in the bigger spring, and that was my problem i think, it must have been intermitantly jamming in the bigger spring effectivly packing it out, a new spring from a spare reg has sorted the issue now, well i hope so anyway because i jumped in the car at 4 this moring to come up to Farnborough and its been fine on the short run up here 8-)
Also no more rocking from side to side, dont ask me how but it isnt, i also need new spheres on the rear now as the back end feels rather firm compared to the front with its new hydractive sphere anyway :wink:
D
XM Prestige PRV6 92
x 8350
Thank goodness you found that Dean :) I've known of failed regulators causing accumulator spheres to literally explode. Brings a whole new meaning to the term 'ruptured sphere' :lol: Seems the pump can make a heck of a lot more than 230 bars if they're not regulated...
An exploding accumulator must be a sight to behold - as well as a sound....
I'm pleased it didn't happen to you...
Deanxm
x 87
So am i Jim, it could have been expensive :lol: i dont think it was jammed solid, i think the inner spring was just interfering with the bigger one and alowing it to reach varying different levels of higher than normal pressure, probably often enough to pop my acc sphere and strain the main feed pipe, amzes me the rocking has gone though, ive done 120miles since monday and still no rocking so make of that what you will, although i do have a theory.
D
XM Prestige PRV6 92
x 8350
I'm very interested to hear your theory Dean :) I can't think of one right now but then my thinking kit is distinctly unhappy this morning :lol:
Deanxm
x 87
Hi all
I know ive said it before but just so its fresh in everyones mind the Activa will be up for sale at CXM, i have aquired a Focus (or will do fri) so i have a spare car and dont NEED the Activa so since it will be on the mainland now would be the perfect opotunity to test drive or take it away :(.
D
XM Prestige PRV6 92
x 8350
Post also in the CXM thread Dean, so that everybody knows... And on Club-XM too...
Be very careful you don't get flattened in the rush :-D I know if I was after an Activa yours would be top choice... Yours and Chris's...
It's a long walk home you know :wink:
Deanxm
x 87
yes it is but i cant see myself selling it on the day, if i do arrangements can be made........................
Flattened in the rush :rofl:
D
XM Prestige PRV6 92
Chris570
x 36
Unread post by Chris570 »
Deanxm wrote:yes it is but i cant see myself selling it on the day, if i do arrangements can be made........................
D
If it does sell i suppose we could use the FCF couriers to deliver you to a port of your choice, you'd have to package yourself up though. (No Bondage jokes please, oh maybe a few then)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
Deanxm
x 87
damn i cant even think of a bondage joke right now either, give me a minute...................
D
XM Prestige PRV6 92
Chris570
x 36
you've had 3 now...
i expect 3
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
Deanxm
x 87
Ive got nothing, its the pressure..................... i'll get me coat :(
D
XM Prestige PRV6 92
