S2 Xantia V6 - Apologies in Advance
gadgetgricey
Unread post by gadgetgricey »
Success.
Wiring all removed and plumbed in correctly. Blower and Seats working as they should.
Now just need to have a look for the horn relay as described a couple of pages back, before I started to add to the problems. :lol:
Cheers
- Dave -
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Yay well done dave.. Three cheers for you....
Nice work..
Just thinking dave.. Are you gonna come to wethrby racecourse...20th and 21st of this month?? Ill be there both days...
Paul
A very sad...
1994 XM 2.1 d auto
x 8385
Excellent news Dave... Can I switch off the scanner now then?
:D :lol:
gadgetgricey
CitroJim wrote:Excellent news Dave... Can I switch off the scanner now then?
:D :lol:
Not yet, I'm sure there will be another problem in the near future.
Just hope its one not caused by myself. :D
- Dave -
x 8385
I'll leave it on for now then Dave :wink:
gadgetgricey
O.k. Got some time the weekend so want to try and get the final bits sorted. Mainly the horn (and if that goes well, the sunroof as well)
Really basic question but where do I start.
Believe the horn relay is one of the ones under the dashboard, but non are clicking and there is also no power to the horns.
1) Can I remove the relays in order, hopefully identify what has stopped working each time. When I am left with a relay removed and everything else works, that's the faulty one
2) Or is there a way to trace the fault back from either the horn push or the horn itself. Have already connected a couple of wires from the horn connections, so could in theory test the circuit from somewhere.
Never done any investigation like this before, so would be glad of any pointers/help.
Once that's sorted is off to the MOT station with my fingers crossed.
Thanks again
- Dave-
gadgetgricey
Ok as is typical with me, took a little longer than expected BUT the V6 got awarded its MOT today, so its back on the road. :lol:
Only advisory was front brake pads a little low, so might even do that as well.. :lol: :lol:
Just got the rear windows, sunroof and replace a front fog light and everything will then be done.
Everything else seems to be working perfectly, even the air con is working nice and cool........ (not sure how to turn the cruise control on though)
Only had the first drive today, and not sure about the auto box, (As in me driving it, not a problem with the box itself.)
Put my foot down and accelerated hard, scared myself with how quickly we took off :shock:
Thanks again for everyone's input and hoping that I will be able to sort any other problems out that may occur.
Cheers
- Dave -
citroenxm
Fallen Hero
x 70
Hi Dave!
CONGRATS! Yes they doo have some go in it! Imagine that, then think about a bit QUICKER again and faster, you then have an idea of a 24v XM V6 S1 manual :lol:
The cruise has a master switch on the dash, shows a car with an arrow next to it.. cant remember which side of the steering wheel its on in S2 cars, but press that on thats the main power, then when your at your designated speed pull the lever under the indicator towards you gentley and take your feet away - if its all working then away you will go.
IF she doesn't then first thing to look for is a split Vaccuum pipe on the motor, under passenger side front corner bumper.. hidden away. it very useually splits there...
Paul
A very sad...
1994 XM 2.1 d auto
x 1458
Unread post by xantia_v6 »
citroenxm wrote:Hi Dave!
Actually it works the other way..
Lift the lever up to set (or increase) the speed, push it down to slightly reduce the speed, and pull it towards you to disengage the cruise control.
The other common failing is dirty contacts in the switch on the brake pedal.
x 8385
Excellent news Dave :D :D :D :D
This'll help you fix the cruise control...
Every possible fault covered :roll:
gadgetgricey
Cheers all.
Hopefully it will be working, just did not know what buttons to push to engage the system.
Thanks again.
- Dave -
citroenxm
Fallen Hero
x 70
DOH! Senior moment there, OF course it does.. I should KNOW Ive got Xantias and XMs with cruise... Thanks Xantia_v6..
:oops:
Paul
A very sad...
1994 XM 2.1 d auto
