I called Europarts today for replacement Spheres, they can find all on their system other than Front Hydractive - so question is are they the same and I order 2 rear ones?
Also I replaced regulator sphere on my CX Safari with XM Front Hydractive as it has larger capacity 50cl and pressure 70, are they the same on Xantia?
David
Front/Rear Hydractive spheres the same?
Diabolical
06 C5 2.0L HDi Exclusive Estate 20020k and rising.
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
citroencx.co.uk
Dommo
- x 20
Diabolical
I mean Front Hydractive bottom left hand side by the horn.Dommo wrote:They're definitely not the same, GSF stock the hydractive front corners:
453PC0200
Or do you mean the front centre sphere? Either way they aren't the same.
citroencx.co.uk
citroencx.co.uk
- x 8465
They're different. They're both essentially accumulators but front/rear vastly differing pressures. The front is also a bigger volume as well.Diabolical wrote: I mean Front Hydractive bottom left hand side by the horn.
The front is 70bar 500cc whereas the rear is 50bar 400cc..
Here's the full list for a hydractive car..
Diabolical
Thanks Jim
Have now ordered all that's needed. Already had 4 corner spheres for non_hydractive, I fancy a soft/damper ride.
I'm surprised only 50 BAR is on Accumulator sphere.
Front Hydractive is the same as XM it seems.
citroencx.co.uk
citroencx.co.uk
DickieG
- Monaco's youngest playboy
- x 33
That accumulator (SC/MAC) is the anti-sink accumulator, not the front one attached to the engine, be careful when you unscrew an anti-sink sphere as there is the serious risk of twisting the hydraulic supply pipe off, make sure you loosen the union then hold a spanner on the union as you undo the sphere.Diabolical wrote:I'm surprised only 50 BAR is on Accumulator sphere.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Diabolical
Aha, this is the confusion the Guy at Europarts and I had, he said: we have no Anti Sink so I said: don't bother with that I shall just have main Accumulator.DickieG wrote:That accumulator (SC/MAC) is the anti-sink accumulator, not the front one attached to the engine, be careful when you unscrew an anti-sink sphere as there is the serious risk of twisting the hydraulic supply pipe off, make sure you loosen the union then hold a spanner on the union as you undo the sphere.Diabolical wrote:I'm surprised only 50 BAR is on Accumulator sphere.
Thank you for pointing that Out Dickie, could have made a bit of a cock up
citroencx.co.uk
citroencx.co.uk
