Code P1637?
x 94
Unread post by citronut »
if that is your jalopy here is trade price and part No.
00001920AG AIR METRG DEVIC 101.59 GBP 119.37 GBP 119.37 GBP
try aimming that part No. at either your local factors or
http://www.fpuk.co.uk/main/indexfuelparts.asp
or even google it as you will almost certainly get a better price
regards malcolm
x 5648
citronut wrote:is this your car Steve
C5 5 DOOR ESTATE 2.0 HDI 110 Manual gearbox 5
if so you enterd to many six's six's six's six's six's six's :spineyes:
regards malcolm
It is Malcolm and I have discovered why there were an excess of 6s.
Text carries on appearing on the screen long after I have finished typing. I've likely checked part of the number as I can only remember 3 digits at a time, added a six or two and it has filled them in later.
Some oddness with the machine as it is showing CPU at 100% when it is doing next to nothing.
x 94
at least i can still count nine and a half digits at a time, well that is without taking me shoes and sock's off,
i did also with one of my digits google that part No. and amongst the listtings that came up was this one
http://www.worldcarparts.co.uk/CarParts ... fault.aspx
regards malcolm
x 5648
Thanks Malcolm :)
Still haven't had a reply from the dealer, may pop down there on Tuesday and see what they say.
x 94
why pay dealers price :shock: when there are suposadly VALEO units out there for a lot less dosh ,
regards malcolm
x 5648
Some other members have bought non-OEM units and had very disappointing results from them, including a very short life. I am tempted though.
Appreciate the time you took Malcolm.
The one fitted is a Bosch unit that IIRC is not much more expensive than a lot of the aftermarket ones.
I'm still dubious about it being the MAF. I suspect the EGR/sensor/solenoid and the boost sensor too.
x 5648
Bought a MAF from the dealer - at long last, had to order it as they don't hold them in stock.
Ironically the car shot down there effortlessly with no Antipollution fault showing, whizzed along as though nothing was wrong.
Changed the MAF and found the old one much corroded and th 'flyscreen' has a lot of crap in it.
Rather more worrying was that the air filter was soaked - fairly new one, been on about four months. New one ordered.
I did also notice while I was out and about yesterday and today a slight noise a bit like an electronic screech but may be a pneumatic :(
Very faint but needs investigating.
Old MAF, apologies for crap photo's - it is sitting on the desk and they are just p&s shots.
Still haven't found what the code (P1637) was.
cachaciero
x 9
Re: Code P1637?
Unread post by cachaciero »
myglaren wrote:
(May be “CAN link ECM/INSTM circuit / network malfunction “)
CAN link ECM?ABSCM circuit / network malfunction
This I suspect is equivalent to the ABS/ESP warning that the 2.2 throws every time it gets a failure of the engine ECU. The logic on the 2.2 is that the ABS and ESP use computed torque data from the engine, when there is an engine ECU failure torque data is no longer valid so no longer gets put on the CAN bus. I suspect that the same logic applies to the 2.0Ltr.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
x 5648
I only have ABS, no ESP.
If I had ESP I might be able to perceive what ails the blighter :)
Perhaps it relates to the engine being stalled?
It will be back then as my daughter stalled it on Thursday when she went out for a practice drive.
It will be interesting to see how it performs tonight and tomorrow. Going shopping during the night when Asda is quiet and the smokers not blocking the entrance, need fuel to so late at night when the queue isnt half a mile long at the Shell station.
I am concerned about the damp in the filter (and all the sand & gravel)
Last time I changed the filter I drilled a small drain hole in the 'well' thing as it was full to overflowing with water, cleaned the muck and leaves out too. Now there is no water in the well but the filter was soaked.
It has to be the way the 'snorkel' intake hose reaches down into the lower wheel well - brilliant design there Citroen, about as clever as the 306 air filter under the front bumper!
I wonder if some coarse wire wool would discourage it or if relocating it higher would be a better proposition.
I think pulling the airbox out and removing the snorkel would be no worse than leaving it as it is. There was a small amount of water in the MAF housing, wouldn't want that sucking into the engine :shock:
x 1919
myglaren wrote:It has to be the way the 'snorkel' intake hose reaches down into the lower wheel well
Is that the side that a bit of your wheelarch liner broke off? That would certainly explain why the water's getting in.
x 5648
I had also thought of that after the previous post, probably worth rectifying soonish.
Been out in it tonight and the improvement is remarkable.
x 94
the R Secnic D used to be known for the engine hydraulicing after heavy intake of water through the air intake, this use to completly destroy the engine :twisted: ,
regards malcolm
x 1056
Unread post by wheeler »
There was a citroen info rapide regarding the air filter & airflow meter getting wet which involved adding a sealing strip to the front bumper where it joins the wing at the n/s + adding some mastic in certain places.
x 94
wheeler wrote
"adding some mastic in certain places"
oooooh la la :oops: :shock:
regards malcolm
x 5648
Ran fine last night and for an hour or so this morning and then started hesitating a bit on acceleration.
Still miles better than before but clearly need to sort the wheel arch and air induction problem out.
Been out all day in it, buying a car with Annika then taking Laura to get her car and the roads were very wet following a fair bit of snow last night.
