Code P1637?
- x 94
if that is your jalopy here is trade price and part No.
00001920AG AIR METRG DEVIC 101.59 GBP 119.37 GBP 119.37 GBP
try aimming that part No. at either your local factors or
http://www.fpuk.co.uk/main/indexfuelparts.asp
or even google it as you will almost certainly get a better price
regards malcolm
regards malcolm
- x 5688
It is Malcolm and I have discovered why there were an excess of 6s.citronut wrote:is this your car Steve
C5 5 DOOR ESTATE 2.0 HDI 110 Manual gearbox 5
if so you enterd to many six's six's six's six's six's six's![]()
regards malcolm
Text carries on appearing on the screen long after I have finished typing. I've likely checked part of the number as I can only remember 3 digits at a time, added a six or two and it has filled them in later.
Some oddness with the machine as it is showing CPU at 100% when it is doing next to nothing.
- x 94
at least i can still count nine and a half digits at a time, well that is without taking me shoes and sock's off,
i did also with one of my digits google that part No. and amongst the listtings that came up was this one
http://www.worldcarparts.co.uk/CarParts ... fault.aspx
regards malcolm
regards malcolm
- x 5688
- x 94
- x 5688
Some other members have bought non-OEM units and had very disappointing results from them, including a very short life. I am tempted though.
Appreciate the time you took Malcolm.
The one fitted is a Bosch unit that IIRC is not much more expensive than a lot of the aftermarket ones.
I'm still dubious about it being the MAF. I suspect the EGR/sensor/solenoid and the boost sensor too.
- x 5688
Bought a MAF from the dealer - at long last, had to order it as they don't hold them in stock.
Ironically the car shot down there effortlessly with no Antipollution fault showing, whizzed along as though nothing was wrong.
Changed the MAF and found the old one much corroded and th 'flyscreen' has a lot of crap in it.
Rather more worrying was that the air filter was soaked - fairly new one, been on about four months. New one ordered.
I did also notice while I was out and about yesterday and today a slight noise a bit like an electronic screech but may be a pneumatic
Very faint but needs investigating.
Old MAF, apologies for crap photo's - it is sitting on the desk and they are just p&s shots.
Still haven't found what the code (P1637) was.
cachaciero
- x 9
Re: Code P1637?
CAN link ECM?ABSCM circuit / network malfunctionmyglaren wrote:
(May be “CAN link ECM/INSTM circuit / network malfunction “)
This I suspect is equivalent to the ABS/ESP warning that the 2.2 throws every time it gets a failure of the engine ECU. The logic on the 2.2 is that the ABS and ESP use computed torque data from the engine, when there is an engine ECU failure torque data is no longer valid so no longer gets put on the CAN bus. I suspect that the same logic applies to the 2.0Ltr.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- x 5688
I only have ABS, no ESP.
If I had ESP I might be able to perceive what ails the blighter
Perhaps it relates to the engine being stalled?
It will be back then as my daughter stalled it on Thursday when she went out for a practice drive.
It will be interesting to see how it performs tonight and tomorrow. Going shopping during the night when Asda is quiet and the smokers not blocking the entrance, need fuel to so late at night when the queue isnt half a mile long at the Shell station.
I am concerned about the damp in the filter (and all the sand & gravel)
Last time I changed the filter I drilled a small drain hole in the 'well' thing as it was full to overflowing with water, cleaned the muck and leaves out too. Now there is no water in the well but the filter was soaked.
It has to be the way the 'snorkel' intake hose reaches down into the lower wheel well - brilliant design there Citroen, about as clever as the 306 air filter under the front bumper!
I wonder if some coarse wire wool would discourage it or if relocating it higher would be a better proposition.
I think pulling the airbox out and removing the snorkel would be no worse than leaving it as it is. There was a small amount of water in the MAF housing, wouldn't want that sucking into the engine
- x 1955
Is that the side that a bit of your wheelarch liner broke off? That would certainly explain why the water's getting in.myglaren wrote:It has to be the way the 'snorkel' intake hose reaches down into the lower wheel well
- x 5688
- x 94
- x 1061
- x 94
- x 5688
Ran fine last night and for an hour or so this morning and then started hesitating a bit on acceleration.
Still miles better than before but clearly need to sort the wheel arch and air induction problem out.
Been out all day in it, buying a car with Annika then taking Laura to get her car and the roads were very wet following a fair bit of snow last night.
