Hello Guys,
Had a look on GSF for break pads, they are coming out at 35+vat, never paid that for pads in my life.
I've just had a look, the calipers are bendix, I assume there narrows my search down some what when looking on europarts and ebay etc.
CoXen
Bendix Brake Pads
HDI
- x 7
- x 1238
cox377
HDI
- x 7
Try your local motor factor , u might be surprised.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 94
cox377
Kowalski
I've had two TD Xantia's each with different sized front discs. The first had the 266mm discs, the second the 283mm, there is also a third size of disc, 288mm but to my knowledge the 1.9 TDs don't get that size of disc..
GSF list the following types for front pads for the Xantia.
N64019 is for 266 mm discs : £21.50
N64036 is for 283 mm discs : £25.60
N64023 is for 288 mm discs : £27.15
Best confirm the size of your discs and ask GSF which is right for your car to make sure.
- x 94
Kowalski
VertVega
- x 13
cox377 wrote:Hi, sorry it's a 1998 TD xantia.
Is this 1.9 TD or year 98 TD? Mine 2.0 16V has 283mm.
Anyway 1.9 TD front disc should be 288 mm (disc thickness 28 and minimum 26 mm) in the same category as V6.
If it is 1.9 D then it's 266 mm (20.4 mm, 18.4 mm).
Above are given all 3 different sizes of BENDIX front disc (Xantia).
Kowalski
As I mentioned, I've had two TD Xantias and they were both hatchbacks but most importantly, they had different sired front brakes.VertVega wrote:Anyway 1.9 TD front disc should be 288 mm (disc thickness 28 and minimum 26 mm) in the same category as V6.
VertVega
- x 13
Sorry, I should have read more carefully through the replies, I just didn't notice.Kowalski wrote:As I mentioned, I've had two TD Xantias and they were both hatchbacks but most importantly, they had different sired front brakes.
Here is a Xantia Brake Specifications chart. I hope it'll be helpful for other forum members (and guests) as well
(rear disk size is same for all models, that's interesting)
Also 2.0 HDi is seen in both 288 and 283
Toby_HDi
- x 3
IIRC that is because the HDi 90 uses 283mm and the HDi 110 the slightly larger 288mm.VertVega wrote:...Also 2.0 HDi is seen in both 288 and 283...
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
XantiaMan
- x 18
I've never seen 288 on a 1.9 TD. The later S1's usually had 283's, identified by them having 15 inch wheels not 14 inch like the smaller engined petrols.
The brakes on my Activa are 288, and are much thicker than my old TD, plus the caliper design was different, it had pins not bolts.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
2017 Fiesta ST
