Replacing C5 sidelight bulbs.
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
I've got a C5 with xenon headlights - and also a dud sidelight bulb on the driver's side. I've had a quick look but it seems impossible to get in there. Can somebody tell me that I don't have to remove the front bumper!!!
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 1055
Unread post by wheeler »
I take it that it's a mk2 ? It can be done with little hands but it is tight, try gently pulling in the wires once you twist the bulb holder.
Have you got or priced the bulbs yet ? i dont know if anyone else does them yet & they are over a fiver from Citroen :shock: for a tiny sidelight bulb.
JohnD
(Donor 2022)
x 72
wheeler wrote:Have you got or priced the bulbs yet ? .
I've got 5w capless and 5w bayonet in the toolbox. Expected it to be one or 'tuther!
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 1055
It's a 5w bayonet but it has offset pins(if it's a mk2 that is), never seen these bulbs anywhere else yet.
JohnD
(Donor 2022)
x 72
Thanks - never seen them but will have to get a couple.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
JohnD
(Donor 2022)
x 72
wheeler wrote: Have you got or priced the bulbs yet ? i don't know if anyone else does them yet & they are over a fiver from Citroen :shock: for a tiny sidelight bulb.
Job done! But not till after the front bumper was removed. Cit dealer wanted £95 to replace the bulb and even charged me £6.82 for the bulb. Since completing the job I've found http://www.consumabulbs.com/files/bdet.php?id=170
do them at £3.95 incl. p&p.
It's bizarre that you have to resort to this to change a sidelight bulb!
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
mop
Unread post by mop »
Wow :shock: hope my side light bulb never goes.
Talking Bumbers I bought a Citroen reversing kit off ebay and have to take the rear bumber off for it, if I had known that I would not have bothered though having got it now will attempt it, the book says 2hrs so expecting 4 hrs and alot of fustration.
Has anyone ever fitted one?
05 C5
GB
Unread post by GB »
mop wrote:Has anyone ever fitted one?
Fitted a set of Valeo reversing sensors to my 54 reg series II C5 about a year ago. No need to remove the rear bumper bar: reversing sensors can be easily fitted in the existing bumper cavities, and wiring can go through the ventilation cavity under the rear bumper bar (nearside). Just lift of the boot carpets to get a good view and access.
All up, it took me about 1.5hrs, with the hardest bit being identifying the reversing light wire to hook up the control box to.
GB
05 C5 VTR 2.0 HDI
115k
dnsey
x 19
Unread post by dnsey »
Agreed re the reversing sensors, but it's worthwhile removing the rear interior trim from the boot, so that it's clear where the strengthening webs of the bumper assembly lie - obviously, the sensors need to be fitted between them.
bencowell
Unread post by bencowell »
The facelifted C5 has pre-drilled holes blanking covers that simply lift off. Fitting the sensors is the easy bit.
Can anyone help with finding the reversing light wire on a 2006 C5 hatchback?
Ben
Currently driving a 2004 C5 VTR (old shape) and an Electric Kia Soul. Sorry but the electric one is my favourite!
Formerly Hyundai Genesis 3.8 V6, 2 x Kia Optima, 2 x C5, Xsara and Saxo.
x 1055
bencowell wrote: Can anyone help with finding the reversing light wire on a 2006 C5 hatchback?
Pull the n/s boot carpet down & you will find a 16 pin black interconnector in the 'C' pillar area, the reverse light feeds can be picked up there.
mop
The reversing (genuine Citroen part) kit I have use microwaves it a strip that you attach to the full length of the bumper (advertised as no drilling required) . Wish I bought the older one now as you'se have pointed out with a mk II C% it comes predrilled.
Similar to this Here
05 C5
dnsey
x 19
Hmmm. the system you've linked to only claims to start detecting within 80cm, which is a bit too close if you're not aware that there's an obstruction! My system (with four sensors) cost £14 via Amazon, and detects obstacles 1.5m away.
I can see now why you'll need to remove the bumper, but it's not difficult as long as the fastners haven't seized :?
mop
dnsey wrote:Hmmm. the system you've linked to only claims to start detecting within 80cm, which is a bit too close if you're not aware that there's an obstruction! My system (with four sensors) cost £14 via Amazon, and detects obstacles 1.5m away.
Excellent point never even thought to check and the Link revers to one which works better than the Citroen one which range is from 70 cm :cry:
maybe just go and buy one that makes use of pre drilled holes.
05 C5
Citroenmad
x 110
Unread post by Citroenmad »
SO many modern cars need the fronts removing to gain acess to the lights. Do they not expect the car to outlast the light bulbs or something!
I remember Renault wanted £140 to fint a new headlamp bulb in our new shape scenic, as the front needed to be removed. I managed to fit it without removing anything. I knew having skinny arms would be useful! :lol:
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
