Xantia HDI MPG?
Rostami
Unread post by Rostami »
I dont want to get into a silly discussion, but please take a look at:
http://www.conceptcarz.com/vehicle/z241 ... fault.aspx
..the 1.8i version of the C5 has the exact weight as my Activa :P
Xantia Activa 2.0 HDi (1999)
Renault Clio 1.9D (1994)
BX 16TRS (1984) - RIP
Fiat Uno 45s (1987) - RIP
bencowell
Unread post by bencowell »
C5's are 1290 -1558kg unladen! The 2.0 HDI 110 saloon is 1438kg
x 1240
Unread post by Peter.N. »
Its mostly down to the right foot, my XM estate (got to be heavier than a Xantia) averages 40-45 with a best of 55+, but then I'm old and dont drive very fast. :cry:
user_3150
New User
Unread post by user_3150 »
I get abot 550-600 miles from a full tank to the reserve light on average about £50 of diesel. Not sure of mpg but seem quite good.
pikecrazy
Unread post by pikecrazy »
Alec wrote:I get abot 550-600 miles from a full tank to the reserve light on average about £50 of diesel. Not sure of mpg but seem quite good.
I had about the same mpg when i went to thruxton the other week 500 + miles plenty of stick as well :twisted:
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim :-)
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Kerb weight of C5 Estate 1520Kgs
Kerb weight of Xantia Estate (2.1) 1380Kgs.
Jshodgson
Unread post by Jshodgson »
I get 450-500 miles from a full tank in my estate. I average 38-40 mpg and had similar from my last Xantia hatch.
I have read that certain fules are more efficient than others. I think it may the Shell and BP (expensive ones) but haven't tried them so don't know if that affects it at all. I use good old supermarket soup. (all of Sainsbury's fuel is supplied by BP anyway!!)
Had (Saxo VTR 1999 (T) LPG converted - do not ask!!!)
Had (Xantia LX TD 1995 (M) 144,000 miles)
Had (Xantia TD Estate (N) 147,000 miles !)
NOW GOT Picasso 2.0HDi (02) 96,000 miles
bencowell
Its the additives that make the difference.
For example, why do people buy expensive French mineral water rather than supermarket own brand british water? Its just water after all, but one contains more minerals than the other. Its the same with diesel!
Our local Bosch Authorised repairer says that its best to use big brand fuel and an occasional shot of millers doesn't hurt.
Ben
Jshodgson
Do you think the BP fuel Sainsbury's use is a lesser quality than the stuff they have on their own forecourts?
f00lzz
Unread post by f00lzz »
Come on guys... we all know that they supply fuel to a standard as long as you use the correct standard for your vehicle.... what the hell!!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Jon888999
Unread post by Jon888999 »
I've just filled up my Xantia, 603 Miles on 54 LITRES. 50 mpg. The best i've got to date! Normally get around 45 mpg, seems more dependent on the make of Diesel then how it's driven.
BP Ultimate is the worse (41 mpg), Normal BP, Shell & supermarket diesel average 45mpg, ESSO diesel seems to be the best overall.
It does feel quicker on BP ultimate, but not worth the extra price or drop in economy>
Anybody else found these differences? I've done 4000 Miles since the end of march, so the more mpg the better.
Garysz
Unread post by Garysz »
My normal garage is Shell in Wickham out of which I have averaged 45mpg. However, I have changed the oil and added Greased Lighning to the oil (this stuff got me 50 miles per tank more on my old petrol Xantia).
Was going to fill up at the Shell but passed the Sainsburys in Fareham at 95.9p per litre, 1p cheaper than the Shell! so filled up there. I will post the results.
Kowalski
Unread post by Kowalski »
Garysz wrote:My normal garage is Shell in Wickham out of which I have averaged 45mpg. However, I have changed the oil and added Greased Lighning to the oil (this stuff got me 50 miles per tank more on my old petrol Xantia).
The Greased Lightning sections on QVC really do make me laugh.
If an oil additive says it can improve your fuel economy by 10% by reducing friction, they're suggesting that AT LEAST 10% of the energy in your fuel is lost to friction in your oil, it is simply not the case.
"Greased Lightning Extended PTFE Oil" contains PTFE, that is how they claim to be reducing friction. I'll quote Dupont, the inventor of PTFE and holder of the Teflon trademark "Teflon is not useful as an ingredient in oil additives or oils used for internal combustion engines."
Have a read of this... http://www.carbibles.com/snakeoil.html
NiSk
Unread post by NiSk »
To get back to the point, if you were only getting 25-27 mpg from a 2 l Xantia, then 45 mpg from a C5 110 HDI sounds quite reasonable.
//NiSk
'85 BX 16TRS, '91 XM injection 241,000 km (company car), '93 XM TD12 (515,000 km), '98 XM 2.5TD Break (320,000 km)
