Xsara thermostat into brakes?
Stuart McB
On Friday I noticed that the VTR was taking time to warm up so when I got to work I contatced the local Citroen dealer and asked about the thermostat rattings for the Xsara VTr "89c sir and we have then in stock at £8.27". Now I know GSF do them for £8.50 and being a tight wad off I trooped to the dealer. Any how sure enough on removal the old stat had seemed to have jammed half open, but it was rated at 88c so replaced it, flushed the system and refilled with Citroens own coolant. On the test drive at 2 o'clock I heared the dreaded SKREETCH of worn brake pads. S**t [:(] I thought GSF are now shut I'll have to go to H***ords. Any how £30 lighter (with brake cleaning fluid) I set about sorting the brakes. Does any one here under stand the phrase "on the rivets" well they were almost on the metal. Funnily enough every thing came apart at the first attempt, even the brake bleed nipples. All sorted over the week end total time 3.5 hours with lunch and coffe. [:D][:D]
Mosser
uhn113x
- x 3
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Mosser</i>
Interesting !, but i didnt know brake pads were riveted anymore?, i thought they were glued nowdays
I don't think pads were <b>ever</b> rivetted; linings on shoes used to be, though.
Stuart - Is your warning light for pad wear not working? Hope your 'coffe' is better! [}:)]
Stuart McB
uhn113x
- x 3
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Stuart McB</i>
It;s just a phrase we used as kids, my old 850cc mini had drums on the front. Thanks the coffe was fine (spelling)
Yeah - my wife used to have a Min, Stuart. Stopping wasn't its best point; fact is, I cannot think what its best point <b>was</b>, unless you count the fact that you could get quite a big lunchbox in the boot!
JohnD
- x 72
Stuart McB
uhn113x
- x 3
