306 clutches
bad driver
306 clutches
Unread post by bad driver »
I currently have a 306 td with a n/a derv gearbox and clutch / flywheel etc.
I want to put the td flywheel back on and use a td clutch as its bigger, I know one clutch is push and one is pull. Is this just the way the cable pulls? IE will the thrust bearing still be pressed toward the clutch when pedal is pressed and will the td thrust bearing fit the n/a arm?
Dave Burns
x 3
Unread post by Dave Burns »
Push or pull refers to the action of the release bearing on the pressure plate diaphragm spring, none of the parts are interchangeable.
Dave
PowerLee
Unread post by PowerLee »
Isnt the clutch cable different too between Pull & Push types?
