I currently have a 306 td with a n/a derv gearbox and clutch / flywheel etc.
I want to put the td flywheel back on and use a td clutch as its bigger, I know one clutch is push and one is pull. Is this just the way the cable pulls? IE will the thrust bearing still be pressed toward the clutch when pedal is pressed and will the td thrust bearing fit the n/a arm?
306 clutches
Dave Burns
PowerLee
