Hi everyone,
My name is Salvo. I recently managed to retrofit the head unit in my Peugeot Partner van, swapping the old RD45 stereo for a SMEG+ IV2. It took quite a bit of time and patience!
I have Diagbox (v7.40 along with a few other versions), so I successfully coded the new VIN to the SMEG+ unit. My original setup did not have Bluetooth, so I ran the microphone cable to the head unit as well as the cabling for a reverse camera https://www.aliexpress.com/item/1005008 ... 1802o9o7GX
I am now trying to figure out how to get this reverse camera working. Here is what I have done so far:
Wiring (40-Pin Quadlock / FAKRA Part B):
Pin 1: Rear_Cam_IN (+) (Video Signal)
Pin 7: Rear_Cam_IN (-) (Video Ground)
Camera Power: Positive wire connected to the reverse bulb (+12V), negative wire connected to chassis ground.
Diagbox Configuration:
I connected Diagbox to change the camera parameter from Absent to Present, but it will not let me save/telecode the option.
Note: I also have a UART/serial connection setup directly to the radio if that helps bypass anything.
Has anyone run into this issue when retrofitting a SMEG+ IV2, or does anyone know what I am missing to get the telecoding saved?
Thanks in advance for any advice!
Salvo
SMEG+ IV2 Retrofit on Peugeot Partner — Reverse Camera Telecoding Help
salvodipa
- x 8153
Re: SMEG+ IV2 Retrofit on Peugeot Partner — Reverse Camera Telecoding Help
@salvodipa I have removed the first topic you posted from the forum as you requested.
Kees
- x 150
You didn't tell, if the unit comes from a car with a rear camera.
As far as i know there must be some hardware inside, witch you can check with the version of the unit itself.
Kees
- x 150
"connected Diagbox to change the camera parameter from Absent to Present, but it will not let me save/telecode the option."
This means that the bsi don't see the camera, there also need some connection wires to the bsi.
salvodipa
Hi Knees thanks for your answerKees wrote: 07 Nov 2026, 20:43 You didn't tell, if the unit comes from a car with a rear camera.
regarding the unit I don't know if it had before
I bought the unit (SMEG+ IV2) on eBay. Do you think it matters which vehicle the unit came from?
salvodipa
Yeah, you're right. I don't think the positive wire should be connected to the reverse light positive wire. I need to change that.Kees wrote: 07 Nov 2026, 21:00 "connected Diagbox to change the camera parameter from Absent to Present, but it will not let me save/telecode the option."
I've also read a forum thread here https://www.elektroda.com/rtvforum/topic3605971.html : where a user called JendrekMak said that the camera needs to be connected to the BSI (CAN bus).
From what I've read on other forums, several users have said that I should connect the positive wire to fuse F14 instead.
salvodipa
Anyway, I have an update. I connected the positive wire for the camera to Fuse 14, but nothing happens on the radio side. There are no errors or warning messages displayed. It looks like the rear camera function is deactivated or not configured in the radio. So I think I need to get the Diagbox token to activate the camera from Diagbox...
Kees
- x 150
I think, there's a misunderstanding, the camera must be connected on the BSI, this connection is a +can signal and maybe the other wire on the ground, but maybe the can- signal.
Because I have a Citroën i can't help you with the bsi connection numbers, see if you can find someone on the peugeot forum.
You also didn't tell what you see on the screen, when you put the car in reverse, you should see a different picture instead of the parking sensors, when this is not the case, the bsi doesn't there's a parking camera on board.
salvodipa
Hi Kees, when you said 'CAN signal from the BSI', how can I find out which one it is? Do you think Fuse 14 from the BSI is not a + CAN signal then?
salvodipa
also I dont' have a parking sensor on my Van , I want to activate only the reverse camera on SMEG Radio unit, that is all
Kees
- x 150
Fuse 14 is no more then a point where other people the 12V supply are using for, you do this with the signal of the rear bulb.
You say "That you only want the camera activate on the radio"
How do you think that the system creates the screen with the lines you see normally with an original system on a car with an reverse camera.
This is where the can signal is used, because when you put the car in reverse, the signal look for the camera and if it's present all other functions will start.
