1999 Peugeot Boxer 1.9D Static timing
mk1wideboy
Unread post by mk1wideboy »
Hi
Would anyone be able to provide the static timing figure for my 1999 Peugeot Boxer 1.9D normally aspirated engine.
Engine code DJY
Bosch VE pump
Part number:
0460 484 146
R425-18
XUD 211
I've tried several autodata programmes, but none give the static timing for the DJY engine in a boxer with Bosch pump. I've also tried looking at other Citroen and Peugeot vehicles around the same year with the DJY engine code but get different settings, mostly 0.66mm or 1.07mm with a few other figures in-between.
x 1053
Re: 1999 Peugeot Boxer 1.9D Static timing
Unread post by wheeler »
This any help?
mk1wideboy
Hi Wheeler.
Thanks for the reply.
Is the sheet you attached from Citroen or Bosch? What's on sheet 179 and 180 regarding the astrix after the R425/*
The information I get on Haynes Pro for a Citroen Relay DJY is giving the static timing as 1.07mm. Is your data a more reliable source? I had a quick measurement of it the other night and from memory it was around 0.80mm with the cold start cable that's connected to the wax stat disconnected from the injector pump. This would make it close to your data sheet.
