I'm getting error codes P0238 P0098 P0113 P1471 P0104. My car is a Turkish model, non-ABS, 8-valve. These error codes are persistent. I've checked the wiring harness completely; there are no breaks, dents, or oxidation. I thought it might be the ECU, so I replaced it, but that's not the case either. I've also tried the sensors, but I can't get rid of the error.
I tried the new sensors, but the same errors persist even when I clear them; they keep reappearing as permanent faults
C3 1.4 hdi xfurio 8v 2008 model yardım lütfen
onur1995
Sloppysod
- x 396
Re: C3 1.4 hdi xfurio 8v 2008 model yardım lütfen
Hi, this is an English speaking forum, could you please repost in English, if you have difficulties use one of the many online translators.
Merhaba, burası İngilizce konuşulan bir forum, lütfen İngilizce olarak yeniden paylaşabilir misiniz, zorlanıyorsanız birçok çevrimiçi çevirmenden birini kullanın.
Stu
PaulC5
- x 691
Could you also give the definitions for the fault codes but possibly you might have a fault with the MAF sensor, try with it unplugged to see of the codes change after you delete the existing ones. Also note down the freeze frame data before deleting as it might help diagnose the fault.
onur1995
I tried the new sensors, but the same errors persist even when I clear them; they keep reappearing as permanent faults.
