Hi, my 2019 2l seems to have a little of this and a little of that. What should be the relay for the cigarette lighter r3 I believe is actually the horn. Other fuse diagrams online don't include a smaller fuse board next to the main one in the engine compartment.
Kind regards
VIN VF3**************[VIN obfuscated, can be read by forum staff]
Fuse and relay diagram needed please
Chefslot
- (Donor 2026)
- x 14
- x 8126
Re: Fuse and relay diagram needed please
I'm afraid your car is too new for my diagram database but hopefully another member with access to the more modern system will see your post and help out. Good luck.
Chefslot
- (Donor 2026)
- x 14
Thank you Mick. Hopefully someone can help. I've got no power to the fuses on the cigarette lighter and the 12v supply. I'm hoping it's just a relay or they've had them snipped to stop the workmen from draining the batterymickthemaverick wrote: 09 Oct 2026, 15:16 I'm afraid your car is too new for my diagram database but hopefully another member with access to the more modern system will see your post and help out. Good luck.![]()
