Hello
I just had a aluminium oil sump fitted to my XUD7 1.7 diesel it looks like an A/C car sump as it has fitments for what looks like a pump.
But i didnt have the opportunity to find out the sump drain plug diameter for a new plug seal ?. Does anyone know what diameter it might be.
The old steel sump i had on the engine took a 14mm diameter oil seal on the drain plug.
Any help appreciated
Gen II 205 sump plug
- x 8165
Re: Gen II 205 sump plug
There seems to be a fairly large range of seals for your engine so I would suggest the best way would be to measure the external diameter of the sump plug which equates to the internal diameter of the seal and go from there. I have found XUD7 seals ranging from 14mm to 22.4mm with a number of options in between, have a look at: https://www.motor-doctor.co.uk/drain-pl ... 1-7-diesel to see what I mean! Good luck
