Turbo screen bolt 1.6hdi
Mksto
Unread post by Mksto »
Whats peoples view should you remove the mesh screen on the lower turbo oil feed banjo bolt or keep it in ? Fitting a new oip feed pipe and bolt , seen a video a guy saying it would affect oil pressure for the rest of the engine if removed ?
x 8100
Re: Turbo screen bolt 1.6hdi
I'd leave it, why should anyone know better than the engine designers? :)
x 1940
Unread post by Paul-R »
I'm sure I've read that removal of the mesh screen is recommended to reduce the risk of blockage. Wasn't the mesh actually deleted in later years?
PaulC5
x 680
Unread post by PaulC5 »
Early 1.6 hdi engines had a reputation for early turbo failure and changing this screen was part of a mod. Have a read of this topic viewtopic.php?t=46915
Mksto
Thanks for the replys guys
